fuel pressure
Old Jun 20, 2003 | 04:55 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
fuel pressure
offhand what kind of fuel pressure does you stock in tank pump make, around 17-20psi
Old Jun 20, 2003 | 08:34 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Iv'e found that the stock tbi pump can make about 18 psi (with no injector firing) But 15 psi is the most I;ve found that the pump will hold when running under load.
Old Jun 20, 2003 | 09:26 PM
Jproz1167's Avatar
thanks 1500
reason I asked was Im getting 18-20 psi on my fuel rails on my tuned port injection system, so my guess is, some moron at the parts store gave me a TBI pump instead of the TPI pump LOL get to drop the tank for the second time in 3 weeks for joy
Old Jun 20, 2003 | 09:36 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Are you sure its not just your regulator, try pluging your return line. But if the pressure was fine before the pump change then it must be the pump.
If your in need of a new pump try http://www.autoperformanceengineering.com/
there porbably the cheaspest ive found so far.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
