Big Problems!!!
Old Jun 27, 2003 | 11:10 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Big Problems!!!
Help!! My SES light stays on under 2500 RPM; My engine will start and then die immediately afterwards, but it will run after that; and I smell gas when I shut the car off. Any ideas on what the problem is? Thanks in advance for any help.
Old Jun 27, 2003 | 09:41 PM
badxs's Avatar
fuel leak???
Old Jun 27, 2003 | 09:52 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
start by checking to see what code is setting the ses light. then let us know, and we can try to go from there
Old Jun 28, 2003 | 05:03 PM
James Montigny's Avatar
Yes, get the code and don't drive the car anywhere.
What was the most recent change done to the car before this happened?
Anything ingnition, fuel system or computer related?
Old Jun 28, 2003 | 05:41 PM
Engine: L98 and L03
Another question
does anybody elses car idle anywhere near 600 RPM
Old Jun 28, 2003 | 05:44 PM
Engine: L98 and L03
The last thing I did to it was take off the rear hood seal. No changes with the electronics though.
Old Jun 28, 2003 | 05:48 PM
Make sure none of the vacuum lines got knocked loose.
The SES code will be the key to unravel the mystery
Old Jun 28, 2003 | 07:50 PM
Engine: L98 and L03
I had a code 22 earlier. Could a bad TPS cause so many problems? I don't have access to any diagnostic tools utill August when school's back in session. Should I just have it worked on?
Old Jun 29, 2003 | 10:09 AM
Car: 91 Camaro RS
Engine: 305 LO3
Re: Another question
yes, mine idles at 600-700 when in drive
yes your tps being bad or not being adjusted properly will cause the car to run like total crap. you could chase your tail for ever trying other things when all you need is a new and properly adjusted tps.
check to see if you are still getting code 22 if so get a new tps and a digital volt meter, get the new tps on and set properly and that should take care of your problem
BTW when my tps was bad it would only set the ses light off during certan rpm ranges also.
Old Jun 29, 2003 | 04:13 PM
make sure the plug didn't get knocked loose
Old Jun 29, 2003 | 08:20 PM
Engine: L98 and L03
Thanks for all of the help. One more question though, how much does the TPS usually cost and what does it take to adjust it?
Thanks again
Old Jun 29, 2003 | 10:05 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
IIRC, it was like 35 for my s-10 for one of the newer style tps' amde by Borg/Warner. As for adjusting it, both the one on my camaro and the one on the truck are non-adjustable. I think the coding in the computer automatically establishes a 'zero' for the throttle position on each start up.
Old Jun 29, 2003 | 10:42 PM
They're pretty cheap
install is 2 torx screws if memory serves me
Old Jun 30, 2003 | 09:20 AM
Car: 91 Camaro RS
Engine: 305 LO3
on the LO3 in the 91 RS it is held in place by 2 torx screws.
the Borg/Warner tps is rather cheap(If memory serves me right I payed about $15) wile the factory tps is non adjustable the B/W replacement is adjustable and you have to set it.
you will have to use a jumper wire on wires B and C for the tps, connect wire B to the possitive on the digital volt meter and connect wire C to the negative. make sure you get it set between 0.54-0.56 tighten it down and recheck it to make sure it is still set right
Old Jun 30, 2003 | 02:28 PM
Engine: L98 and L03
Many, many thanks to you guys. You don't know how much you've helped.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
