TBI LO3 engine q's
Old Jul 8, 2003 | 08:58 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
TBI LO3 engine q's
ok i have a 88 formula with a 305 tbi lo3.....a couple quick questions......does this motor have roller lifters and even though the heads dont have centerbolt valve covers are the head's intake bolt holes drilled like 86 up heads
Old Jul 8, 2003 | 09:12 PM
iroc22's Avatar
They have roller lifters.
They're supposed to have centerbolt valve covers. If you dont have centerbolts, then someone has changed your cylinder heads and that means changed the intake to a pre-86 bolt pattern.
Old Jul 8, 2003 | 09:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
or they changed the whole engine, and he doesn't have a roller block, and doesn't have roller lifters.
Old Jul 8, 2003 | 09:18 PM
Car: 83 Camaro
Transmission: th350
i know the engine is messed with cuz it is all in pontiac blue paint so it could have been replaced then...and now that i think about it the tbi intake's center bolt holes did look kinda goofy and elongated
Old Jul 8, 2003 | 11:41 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
i thought tbi motors didn't have roller lifters
Old Jul 9, 2003 | 08:30 AM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
mine sure did
Old Jul 9, 2003 | 10:55 AM
SLOWTBI's Avatar
Personally i would run the numbers on the block and heads to really see what you're working with here. there is no use spending time shopping and setting up a mod list only to have to 1.) do it all over again or 2.) buy the wrong parts and have to go through the whole return process.
Old Jul 9, 2003 | 11:33 AM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
l03 was def a roller motor except for like some wierd year i'm not sure but chances are you def have roller lifters eventhough our cam sucks
Old Jul 9, 2003 | 11:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
chances are he has one if it is a 87+ Car Block. if the engine has been changed, it may not be. it is also not for sure that even if it is a roller block that it is a roller cam. it is entirly possible that thye rebuilt it, and put a cheap flat-tappet cam/lifters in. if i were him i would research what he actulay has, instead of trying to assume anything about the engine.
Old Jul 9, 2003 | 01:08 PM
Engine: L03 305 TBI
aside from pulling the valve covers, is there any way to tell whether you have a roller cam or not?
Old Jul 9, 2003 | 07:45 PM
iroc22's Avatar
Not really, you will need to take the intake off to see if there's roller lifters.
iroc22's Avatar
All V8 TBI motors in Caprices and F-Bodies had roller cams and lifters.
Old Jul 9, 2003 | 10:02 PM
deadtrend1's Avatar
get numbers off it and go to mortec.com
Old Jul 10, 2003 | 12:57 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If you pull the rockers covers and shine a flashlight through the oil return holes between the pushrods, you'll be able to see if the retainers and big "spider" thingy is there.
Even if it isn't you should be able to see the center of the lifter valley and see if the block has the provisions for the retainer, plus you'll see the "notches" that give clearance for the retainers on the sides of the lifter valley.
Here's a pic of the hole you'll be able to look through.
Attached Thumbnails TBI LO3 engine q's-tbi-heads-pushrod-slot
Old Jul 10, 2003 | 12:59 AM
AJ_92RS's Avatar
Here's a pic of a roller block lifter valley so you know what to look for.
Attached Thumbnails TBI LO3 engine q's-roller-block-lifter-valley
Old Jul 10, 2003 | 04:51 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
Im pretty sure 90-92s did.
SSBO
Old Jul 11, 2003 | 09:35 PM
iroc22's Avatar
Here's your answer.
xkingcodex
Feb 12, 2020 07:43 PM
junkcltr
Aug 2, 2019 11:12 PM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
