How you like my setup?
Old Jul 20, 2003 | 11:54 AM
t-rally's Avatar
zz4 cam
vortec heads complete with performance springs good from 500+ and milled to 58 cc
power plus vortec specific intake manifold
5.7 lt. tbi unit custom made for my application
tbi spacer
custom chip by tbichips.com specifically made for my application
what do you think of my combo, problems i might run into. and what horsepower do you think ill make and what time do you think i can get at the track considering my other mods.
Old Jul 20, 2003 | 12:16 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I helped out a guy with that exact setup on here. DevilsAdvocate, i think. He ended up switching to carb though, he didn't want to mess with the tuning part. He ran a 13.16 last week, not bad for a 305. One thing I would suggest is don't mess with a 5.7 TBI, just go ahead and get a holley 670 tbi. Also don't expect the custom tuning to be a one time perfect thing, it's a slow process and takes a few chips to get it perfect.
With proper tuning you should have a mid 13 sec car.
Old Jul 20, 2003 | 05:16 PM
25THRSS's Avatar
Don't you mean a 14.16? I dont think he was able to break into the 13's with his carb. I actually believe he would have been faster with the tbi, but oh well.
Old Jul 20, 2003 | 05:54 PM
t-rally's Avatar
I actually tried to buy the holley 670 tbi a few times on ebay but i lost the auctions. After doing some research on here ive heard some bad things about the holley units and about customer service for the holley tbi's. Ive also wondered about going carb but I have usually been swayed over to the tbi side.
Me and my dad are going to try to install everything ourself and was wondering if you guys had any tips on getting everything done right or maybe some forewarning on problems i might run into such as the throttle bracket placement?
And any other comments or suggestions are welcome. I havent bought my tbi unit yet so i still can be swayed to go carb!!
and if devils advocate went 13.1 with this setup i am very eager to see what my setup will do. even if he went 14.1 id be happy. i originally was going to go with the lt1 cam but heard from people that alllready have it that they wished they would of went with a little more radical of a cam. its just a matter of how much tuning you want to do, but when you do finally tune it right *** damn do you have a fast *** peice of american muscle!!
Old Jul 21, 2003 | 12:20 AM
Car: 89 Camaro RS
Engine: 305 TBI
Your right, it was a 14.16 @ 96 mph. He said it was still running really rich, so my guess is that it's a mid 13 sec setup.
And yes, alot of us who went with LT1 cams wish we went bigger, me being one of them. The good side was I didn't have to upgrade springs on the vortecs to run a LT1 cam. I'm positive that I've got a low 14 sec setup with some more tuning work. If I can get down to a 14.2 or so I think with DR's I could break 13's. So your setup will take alot of computer tuning but I think you'll be more happy with tbi than carb. Simply because computer control, and computer monitoring is "very niice".
Old Jul 21, 2003 | 09:15 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
sounds like a descent setup, the ZZ4 cam made it to my 'final' list of cams, i descided to go with something that IMO will make a little more power, but i paid for it getting a custom grind cost me, hopefully it will all be worth it ! ! !
i too, think with that setup, you should be running a holley 670, or at least a 454 unit, IIRC the 5.7 TBI, is the same size as the 5.0, but has diffrent injectors (someone correct me if i am wrong) and reality is, the 305 unit, just will not flow what that engine of yours is going to need at the upper RPMs. and with your cam, your power is going on the upper end.
Old Jul 21, 2003 | 11:22 AM
t-rally's Avatar
the funny thing is i lost auctions for both the 670 tbi and the 454 tbi. im waiting for some more to get on ebay because i dont feel like paying upwards of 300bucks for a tbi unit.
Old Jul 21, 2003 | 11:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
you might also head out to your local scrap yard, maybe you could find a 454 TB on a truck might be worth a trip.
Old Jul 21, 2003 | 03:38 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
there's a guy on ebay selling stock tbi units bored out to 2" with the throttle shafts milled down for 159.00 exchange. that's cheaper than i've seen holley 670s and 454 tbis go for on ebay.
i think that's the best way to go. all the linkages and plugs bolt directly on. all you need to do is take your intake to the machine shop and have the holes enlarged to 2". something you'd have to do with the holley or 454 tbi units, anyway.
now, i'm sure someone will come on and tell of finding that 670 holley only used by a little old lady on sundays for 5.00, but, in the real worls, 159.00 is hard to beat.
Old Jul 21, 2003 | 03:46 PM
Engine: L03 305 TBI
the trick to winning those auctions is to "snipe" them.
you wait till there's less than 10 seconds on the auction to put in your bid. that way, there's not enough time for ebay to automatically place a reply bid from the current high bidder.
out of the last 10 auctions i've sniped, i've only lost 2. there's actually software that'll snipe for you. i know at least one of the auctions i lost was to a guy with that program.
good luck
Old Jul 21, 2003 | 05:12 PM
t-rally's Avatar
what do you guys think of this. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2424436286
sounds promising. should i place a bid.
and i am not able to snipe most of the time because i work construction 12 hours a day. thanks for the feedback. keep em coming!!
Old Jul 21, 2003 | 07:39 PM
Dewey316's Avatar
Car: 1990 Camaro RS
http://en.snip.pl
now you don't have to sit in front of the computer!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
