help w/ timing
Old Jul 26, 2003 | 12:15 PM
sniper_dsl's Avatar
Car: '93 Full-size Truck
Engine: 350 Vortec
Transmission: 4L60E w/ shift kit
help w/ timing
pulled the distributer and stupidly forgot to mark it. what is the basic, accurate way of setting up timing? i know to get the no1 pistion up by checking with the plug out and a wire... but how do you know if the valve is letting in air or exiting exhaust? i'd hate to be 180o off when i start the motor...
hopefully somebody knows of a simple step-by-step method... its a 350 vortec w/ TBI. thanks!
Old Jul 26, 2003 | 01:34 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
get it to TDC, back the engine up a bit, then turn it forward, have a buddy put his finger over the #1 plug hole, you should be able to tell if it the compresion stroke or not that way. also if you pull the valve cover, it is really easy to tell which stroke it is on, but watching the rocker arms.
Old Jul 26, 2003 | 02:11 PM
sniper_dsl's Avatar
Engine: 350 Vortec
that clears things up a bit. but i'm still confused on how to setup timing the rest of the way... if i didn't mess with my harmonic balencer would turning the notch back to the degree marks reset back to TDC when it was assembled?
then how do i troubleshoot the off-set distributer? i've never timed a motor before.. i'd like to get it as accurate as it should be.
Old Jul 26, 2003 | 04:11 PM
Dewey316's Avatar
Car: 1990 Camaro RS
find TDC off the compresion stroke, then put the dizzy in with the rotor pointed at the #1 plug wire, the timing mark on the harmonic balancer should read 0* with it at TDC (that is if it is correct) from there you crank the engine over, and hook your timing light up, you the 'spin' the dizzy cap until your timing is where you want it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
