estimates for this combo...
Old Aug 3, 2003 | 01:00 AM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
ok, for my rs, i was considering the following mods...
slp posi and 3.42 gears
1 3/4 headers(don't know which) , catco cat and slp exhaust
port/polish LB9 heads w/ 1.6 rockers
ultimate tbi, and custom air intake from tpi dual element
chip, dual fan setup, weight reduction (seats, some trim panels, spare tire, rear shade cover
what would i be looking at as for est power or 1/4 times? just wanted to know if this seemed like a decent combo till i can get a built 350 in another 18mos.
other mods in sig
thanks
mike
Old Aug 3, 2003 | 08:42 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It is a nice starting point but I didn't see a cam listed in there. You need to get a cam with that combo. I wouldn't use 1 3/4" headers on a 305. Some people do and will tell you its fine but I say stick with 1 5/8". But I am assuming you want to use these on your 350 down the road so I can see why you would want these. If your 350 is mild the 1 5/8" will work fine as well. If you add an LT1/LT4 cam on top of that combo and you get a GOOD custom prom you can probably see anywhere from mid 14's to mid 15's. Your et's will drop if you add some suspension to that combo.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
