hey guys ? on a nitrous kit
Old Aug 11, 2003 | 07:51 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
well seens im gonna put a carb manifold on my engine with a tbi adapter,i was wondering if i could buy a carb nitrous kit which is alot cheaper used and bolt the nitrous plate first on the manifold follow by the tbi adapter and tb will this setup work?
Old Aug 11, 2003 | 08:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well it might 'work' but the spray bar will not be idealy located, you want it in the middle of the air stream into the engine. i am also not sure if you will have hood clearance for a adaptor, and nitrous plate.
Old Aug 12, 2003 | 08:17 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
well hood clearnce is not a problem but i wloud like to know if it works good or if i should just save and get the tbi kit?
Old Aug 12, 2003 | 08:20 AM
Dewey316's Avatar
Car: 1990 Camaro RS
well you don't need to get the TBI 'kit' you can get a 4bbl kit, and then get a TBI plate. you will then have to rejet the fuel side for the diffrence in fuel pressure between carbed apps, and TBI.
Old Aug 12, 2003 | 11:47 AM
bigREd car's Avatar
Car: camaro
Engine: mighty 305
Transmission: mighty 700r
how hard is it to re-jet? i thought the only adjusting on n2o kits is the selanoids i know i spelled that wrong... then again i have no idea.. fuel pressure between tbi and carb isnt much.. not compared to tbi to tpi...
let me know about this re-jetting since this was my idea as well.. get a cowl hood and use a carb kit with tbi adapter..
Shawn
BRoss99
Aug 10, 2025 05:08 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
matthew911
Aug 12, 2015 09:38 AM
mx127
Aug 10, 2015 08:13 AM
