What RPM should a 700R4/LO3 shift at full throttle?
Old Aug 26, 2003 | 11:03 AM
TBI89Formula's Avatar
When I first bought my Formula It ran 16.2's @ 83mph consistantly... a year later the car runs consistant 16.7's @ 83mph! It is my 0-60 times which are suffering. The car used to spin the hell out of the right rear tire when id punch it, now it just hooks up like its got no power. I was reading through my shop manual and It said something about how a torque converter can go bad (cluthes 2 & 3 run together)... resulting in performance loss from 0-35 mph.
My car is shifting at like 4000, is this normal.
If anyone has an Idea of what could be wrong with my car please let me know.
Thanks, Ben
Old Aug 26, 2003 | 11:40 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
4000 rpm shift point is normal for the 700-r4 that comes with the l03. Have you done a tune-up recently?
Old Aug 26, 2003 | 01:42 PM
Yea I have done:
MSD Wires, AC plugs, GM fuel pump, cap/rotor pwrmaster 140 amp alternator.
Between the dead fuel pump and the gm replacement fuel pump I had a gratelli HI FLO pump that was pushing way to much fuel for about 2 months. My fuel pressure gauge at that time was way past the 15 psi limit. I wonder if that could have messed up my injectors or my regulaor. The regulator now reads 11 psi.
Old Aug 27, 2003 | 07:02 PM
25THRSS's Avatar
mine shifts at about 4300-4400 rpm.
Old Aug 28, 2003 | 10:20 AM
Red_Demon's Avatar
From: Currently State College Pa, Usually, I live out side of philly.
mine redlines.. of course my tranny is also broken right now..
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
i have a 700-r4 and it shifts about 4100 - 4200 rpm
Old Sep 1, 2003 | 08:07 PM
armac's Avatar
Car: 83 ta
had mine rebuilt and as long as I am on WOT it want shift untill I let off of it. RED LINE KOBOOM if I am not careful
Old Sep 4, 2003 | 10:56 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
Mine shifts right at the 5000 rpm redline. It's got me concerned b/c it seems too late for performance & the possiblitiy of gernading the engine.
I recently adjusted the TV cable per the procedure available in the Tech Articles. The shifts seem a little firmer, but the shift points are still the same.
https://www.thirdgen.org/newdesign/tech/detent.shtml
Old Sep 8, 2003 | 09:16 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Mine shifts at 4750 - 5000RPM. Stock to my knowledge, and therefore mushy.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
