Connector on TBI
Old Sep 1, 2003 | 09:10 AM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
Connector on TBI
Anyone know what the connector going into the side of the TB (Pass. side, right infront of that vacuum thingy) does? I think it has four wires going into it.
Chris
Old Sep 1, 2003 | 09:50 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
If it is the sensor on the end of the throttle shaft, it is the Throttle Position Sensor (TPS). If it just behind that, it is the Idle Air Control (IAC). It sounds like it is the IAC.
S-D
Old Sep 1, 2003 | 10:15 AM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
The IAC is on the air cleaner, isn't it? It does seem to be on something like a shaft, so maybe it is the TPS.
Old Sep 1, 2003 | 11:11 AM
camarowraith's Avatar
Car: 92 Camaro
The 4 wire connector to your TBI IS your Idle Air Control. [IAC]
The Imtake air Temp Sensor, [IAT] is in you air intake (air Cleaner) housing. The [TPS] is a 3 wire.
Old Sep 1, 2003 | 04:50 PM
cmpcpro's Avatar
Car: 92 Camaro RS
Engine: 305TBI
AAAhhhhh! Okay, well, I tapped into the blue/black wire, (to switch on a relay, NOT suply power to it) and it seemed to act funny, as in, the wire no longer had power when I turned the ignition on, but after I untapped it, and started the car and turned it off, the wire got power again.
Everything seems like its runing alright, could I have damaged anything?
Thanks!
Chris
Old Sep 1, 2003 | 07:32 PM
Car: 1991 RS
Thanks!
Chris
What is your end goal? Spray? Using either the TPS or IAC to signal a relay is dependent on the chip and engine function and can produce varying degrees of success.
What is the story?
C'mon man, give it up!
Best of luck wth whatever it is-
S-D
Old Sep 2, 2003 | 11:35 PM
HaulnA$$'s Avatar
The IAC is a stepper motor that drives a pintle using 2 coils (hence 4 wires) and a worm gear. A stepper motor works by pulsing the coils in sequence driving the motor in steps. Changing the polarity of the pulses changes the direction of the motor. This explains why you could see "power" on a wire only sometimes, depending on the position of the motor. Trying to use one of these signals to drive a relay is not a wise thing to do as the relay would be pulsing with the motor drive signal. When looking for a power source, you should always use a volt meter.:nono:
Wylecoyote08
Sep 8, 2015 08:26 AM
Ironhead38
Sep 7, 2015 02:26 PM
Chevy86 IROC-Z
Sep 7, 2015 01:13 AM
middian
Sep 5, 2015 01:42 AM
