What tool did yall use to grind down ridges on Ult TBI?
Old Sep 1, 2003 | 04:12 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I purchased my dremel today and it came with a whole bunch of parts, but I don't think it gave me what I need to grind down those ridges. Does anybody have a picture of the attachments they used to do the ultimate TBI?
I grinded one piece until it broke off.
Thanks guys.
Old Sep 1, 2003 | 04:21 PM
lykan's Avatar
the best tool I found was part #409 cut off wheel I used that to actually cut off the ridges, and then the stone to smooth it out and radius, then the wire wheel/buffer to smooth it all out.
The reinforced cut off wheels are even better, but they are a bit more spendy.
I suggest the dremel kit #687 came with everything I needed and a bit extra, 12.99 cheaper than all the tips seperately bi-mart had em instock )
Good luck I loved the way the mod helped out not a lot, but noticable.
Old Sep 1, 2003 | 04:48 PM
Car: 91 RS
Engine: 350 TBI
Yup that's what I was using. I've gone through 2 of them already and I don't even have one whole ridge off yet.
I think I need to go buy more of them.
Old Sep 1, 2003 | 04:57 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I used a BridgePort milling machine and a 1" endmill , then some 1/2" cartridge rolls on an air grinder.
Old Sep 1, 2003 | 05:38 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Here is the bit that I used to put the actual radius into the lip of the TBI. I used a cutting disk to cut the ridge off and then went around with the bit I just described.
Attached Thumbnails What tool did yall use to grind down ridges on Ult TBI?-mvc-003fa.jpg
Old Sep 1, 2003 | 06:26 PM
boogie's Avatar
A hacksaw works well for starters to get the bulk of the ridge off.
Old Sep 1, 2003 | 07:12 PM
JPrevost's Avatar
Car: 91 Red Sled
I've got you beat. 1" endmill AND a fly cutter.
!CamaroDave
Convertibles
Sep 17, 2015 12:53 AM
Glowsock
Sep 11, 2015 11:09 PM
hdis2002
Sep 8, 2015 02:52 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
