best oil for old engine
Old Sep 17, 2003 | 06:49 AM
CamaroRS91x's Avatar
Hey guys.....quick question.....My car has about 149k miles on it.....I was thinking of putting synthetic mobil 1 in it...but I'm not sure. what do you think the best oil/filter combination would be for an older engine? Thanks
Old Sep 17, 2003 | 09:28 AM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
valvoline max life w/ valvoline oil treatment. wait till you see the awsome oil pressure youll have then. in my truck at 200 degrees it barely held 10 psi at idle with mobil 1. now, with the above oil and additive, it never goes below 25 psi even at 220. give it a try, you wont be dissapointed!
Old Sep 17, 2003 | 09:30 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
mobile 1 makes a great product, but switching to it on a high milage engine can be troublesome, mobil actualy cleans your engine, and the gunk it disolves can get stuck in oil passages ect, and cuase some problems.
Old Sep 17, 2003 | 09:36 AM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Also switching to a synthetic oil on a high mileage engine might cause the engine to start having oil leaks. Plus your paying alot more per quart.
Old Sep 17, 2003 | 02:39 PM
kristopheer's Avatar
i'll give this a try, i'll let you know how it works.
Old Sep 17, 2003 | 06:15 PM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
Oil
I agree switching to synthic at this stage would cause you more harm than good, plus at that mileage you can't replace worn metal. I think slick 50 is also good for an older motor with high miles.
Old Sep 17, 2003 | 10:54 PM
BigBadJap's Avatar
Car: 1989 GMC Jimmy Fullsize
Engine: 5.7L TBI (LO5)
If you're motor IS leaking now, you definitely don't want to go to synthetic.
There are several high mileage oils on the market now that claim to condition/revitalize seals - I think that an oil like that would be your best bet. Maybe go up a grade too, from 5w30 to 10w30. Probably wouldn't hurt as long as you don't get really cold weather.
... just my two cents.
Old Sep 18, 2003 | 01:21 PM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
You shouldn't be using 5w30 anyway. If you've got minor oil leaks, use 10w40, otherwise 10w30.
89GTAOz
May 16, 2020 09:31 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
