What tools do I need to know what codes my computer is putting out?
Old Sep 21, 2003 | 02:01 AM
vrooom305's Avatar
The title pretty much says it all.
Old Sep 21, 2003 | 02:07 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Rather than explaining it all, go here to find out, after you read it, go try out your new skill.
Kevin
Old Sep 21, 2003 | 02:09 AM
vjo90RS8's Avatar
Car: 2002 Z28
connect the A and B terminals of the ALDL connector with a wire or paperclip (upper right hand terminals), turn the ignition on the ON position and the CHECK ENGINE LIGHT will blink the codes.
Old Sep 21, 2003 | 10:01 AM
vrooom305's Avatar
Ok, I just did this and my SES light started blinking but no codes were shown, not even a code 12. Does code 12 only appear if there is a error code or should it appear even if there is no error code?
thanks again
Old Sep 23, 2003 | 04:46 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
yes the Code 12 should always be there. You have to count the blinks. It should repeat 3 times then go to the next code if any. If no code 12 then it may be a problem with the ECM itself.
gta90
Sep 15, 2015 04:00 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
apie2546
Aug 10, 2015 05:43 PM
