cam install tech article
Old Oct 13, 2003 | 05:27 PM
TMoNeE's Avatar
Car: 87 Z28
will one of you pro's please write one so us newbs have an idiots guide to cam install's... pretty please?
Old Oct 13, 2003 | 08:07 PM
25THRSS's Avatar
Get a helm's manual. Even if it's your first try, it's really easy. The only thing to watch out for is not messing up the bearings.
Old Oct 13, 2003 | 09:17 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
LOTS or info on the WWW about swapping cams in a SBC.
Old Oct 13, 2003 | 11:19 PM
JakeOKC's Avatar
I wanted to install a new cam too, but what about all the timing crap? Dont you have to turn it by hand and set each valve or something?
Old Oct 13, 2003 | 11:21 PM
25THRSS's Avatar
nope, all you do is line the 2 dots up and then make sure the rockers are on right and then you just time it with the dizzy.
Old Oct 14, 2003 | 12:21 AM
vjo90RS8's Avatar
Car: 2002 Z28
get a haynes manual, everything you will need to know is in there. Also check this out
https://www.thirdgen.org/techbb2/sea...der=descending
Old Oct 14, 2003 | 07:30 PM
JakeOKC's Avatar
Well, I always heard about "degreeing" the cam, and I thought you had to turn it and stuff. I think this would probably not be something I would do without help from someone who has done it before.
Old Oct 14, 2003 | 08:55 PM
25THRSS's Avatar
I never degreed mine.
Old Oct 15, 2003 | 06:53 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you should just need to install the cam straight up (no degreeing) most performance cams have 4* or 6* of cam advance already there (they grind say a 112 LSA cam on a 108 centerline) they do this so you dont' have to degree it.
as for setting each valve, you don't set timing by each valve (that is what the cam is for), but you do need to set the valve lash.
Old Oct 16, 2003 | 07:14 PM
JakeOKC's Avatar
Setting the valve lash must be what I am thinking of, I have no idea how to do that. Plus, I dont have a cherry picker anyways I imagine it would be very difficult to change a cam without that.
Old Oct 16, 2003 | 09:40 PM
deadtrend1's Avatar
dont need to pull the motor, nor lift it, nor pull the accessory brackets off the front. Just the waterpump had to come off.....
Old Oct 16, 2003 | 09:46 PM
25THRSS's Avatar
That's why you need to get a helm's manual. It will tell you everything you ever wanted or need to know about your car and more. It was the best money I have ever spent on my car. You can be an idiot and not know a cam from your *** and still do the swap with this book. Seriously man, if you could type something in this thread, you can do it. It may seem hard at first, but it is honestly nothing.
Old Oct 16, 2003 | 10:15 PM
Dewey316's Avatar
Car: 1990 Camaro RS
yeah it isn't bad to do a cam swap, setting lash is pretty easy. for most it is probably easier to do with the engine running, as it takes a certain special feel to find zero lash by feeling the pushrod (that sounded dirty )
Old Oct 17, 2003 | 04:20 PM
TMoNeE's Avatar
Car: 87 Z28
are you talking about the helms service manual thats like 20 bucks, or the helms manual thats like 189 bucks
Old Oct 17, 2003 | 09:55 PM
25THRSS's Avatar
It costs $90 exactly from helminc.com
Old Oct 18, 2003 | 02:37 AM
JakeOKC's Avatar
You can get the cam in there with the engine in? I figured the radiator would be in the way.
Old Oct 18, 2003 | 02:38 AM
25THRSS's Avatar
all you do is take the radiator out. Simple.
Old Oct 18, 2003 | 08:55 AM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
I just did mine a few weeks ago.I pulled the waterpump,radiator,front AC(in front of the radiator) AND took off part of the air dam.Those crossing bars in the nose were in the way too.
It was my first time doing it.I actually had to change the timing chain so I got rid of the peanut while I was there.I changed the timing chain,cam,intake manifold and lifters.I worked on it 6 hrs one day and 7 hrs each two other days.Like I said,it was my first time so I was slow and careful.
It was a learning experiance and hellalotta fun!
specialized
Jun 18, 2022 09:26 AM
mustangman65_79
Apr 14, 2017 05:37 PM
anesthes
Mar 10, 2016 10:35 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
red90IROCls1
Aug 25, 2015 06:56 AM
