Code 44
Old Oct 16, 2003 | 11:07 AM
MikeRush's Avatar
Code 44
Getting engine code 44 - lean mixture. I'm smelling gas while driving and their are no signs of leaks. Checked the fuel filter and lines and haven't seen anything. I'm now getting 12 mpg so wherever the leak is its a big one. Anyone have any ideas?
Old Oct 19, 2003 | 10:39 AM
Carl's Avatar
Car: '92 Caprice
Transmission: 4L60
I have strted getting the same code 44, but only right after enrichment mode/warm up and then it will go away and not come back until the car has sat long enough to get cold again. So it is only during the transition between cold and really warmed up. Any ideas before I start checking and replaceing?
Old Oct 19, 2003 | 11:51 AM
MikeRush's Avatar
Well after I tested everything imaginable it came down to my fuel injectors. I would test your resistance on them, mine was 6.5 ohms on my 305 tbi. It should be higher if you have a 350. Check your fuel pressure too, should be around 13psi. Good Luck
Old Oct 19, 2003 | 04:08 PM
Carl's Avatar
Car: '92 Caprice
Transmission: 4L60
I also have a 305, are they suppose to be 6.5 ohms or is that what you had on your's?
Old Oct 19, 2003 | 10:04 PM
MikeRush's Avatar
There supposed to be, my new ones were 6.5. If its higher you running rich, lower running lean.
Old Oct 20, 2003 | 07:34 AM
Carl's Avatar
Car: '92 Caprice
Transmission: 4L60
Thanks for the info - will check them first.
Old Oct 20, 2003 | 07:41 AM
MikeRush's Avatar
No problem. Good Luck.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
