Need Help
Old Nov 3, 2003 | 05:32 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Need Help
What is the sensor located on the passenger of the block? Is is right under the manifold. When i took it out, antifreeze came out. i am putting headers on and when i took the manifold off i broke the sensor.
thanks.
Old Nov 3, 2003 | 06:02 PM
67 ss's Avatar
Car: camaro
Engine: 355 w/supercharger
Transmission: 700 R4
Is it down in the block just above the oil pan rail? If so it sounds like you broke the knock sensor. It screws into one of the coolant drains for the block.
Old Nov 3, 2003 | 06:10 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
It was just under the manifold in the center.
Old Nov 3, 2003 | 07:10 PM
Zac's92's Avatar
that's your fan switch
Old Nov 3, 2003 | 07:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Was it this? If so that is your fan switch. i busted mine when I put my headers on.
Old Nov 3, 2003 | 07:55 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
yup thats the fan switch, I think everybody breaks it off when doin the headers I did. Try to get a lower fan turn on temp like 170 for little better cooling. You may also need the little clip that goes onto the fan switch mine was very brittle so I replaced it as well. And dont forget to drain the coolent from the block, I got sidetracked forgot to drain it a bit and lets just say the drive was needing a good hose down
Old Nov 3, 2003 | 08:07 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
On a plus side my fans stay on all the time now. As soon as the car starts they come on and stay on. Are the Jet fan switch's worth it?
Old Nov 3, 2003 | 09:16 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
YES!! Thats it. Thanks a lot. Ive got my fan hooked up to a switch. Wonder if i should replace it? But anyways, thanks again.
