what gears in
Old Nov 10, 2003 | 12:19 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
what gears in
hey what gears should a 87 posi disc rear end from a firebird have?
Old Nov 10, 2003 | 12:43 PM
iroc22's Avatar
350 TPI car - 3.27
305 TPI car 5 speed - 3.45
Old Nov 10, 2003 | 11:17 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
and thats a 100% sure its 3.45 cus if it is i will have a 87 disc posi rear end from the 87 bird that was 305 tpi manual in my stock 2.73 posi and boy i will see a diffrence
Old Nov 10, 2003 | 11:18 PM
iroc22's Avatar
Those are the only 2 gear ratios available in the 9 bolt disc rear end in 87. It will be a huge improvement over the 2.73 rear, you will definitely be pleased with the change.
Old Nov 10, 2003 | 11:21 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
i thin kit a 10 bolt not 9
Old Nov 11, 2003 | 01:12 AM
iroc22's Avatar
If it's a 10 bolt then it shouldnt be a 87..in 87 the only rears that had discs were 9's. Better go count the bolts.
Old Nov 11, 2003 | 10:06 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
I took it off a 87 bird but i guess ill count the bolts
Old Nov 11, 2003 | 10:50 AM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Third gens came out with 9 bolt?
I thought GM only manufactured 10 and 12 bolt rearends?
Mine is out of an 86-87 z28 10bolt 3.73 & posi disc rearend.
Old Nov 11, 2003 | 12:03 PM
iroc22's Avatar
In 87 all TPI cars were equipped with the 9-bolt BW 7.75" axle. Some Pontiacs got the 9-bolt before 1987 though.
Old Nov 11, 2003 | 02:40 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
yeah its a 9 bolt.are they any good besides they have the gears i want?how much power can they hold with good strong parts?
Old Nov 11, 2003 | 02:41 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the 9 bolt is stronger than the 10bolts. problem is there is hardley any aftermarket for them.
http://9bolt.com
Old Nov 11, 2003 | 08:53 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
yeah i never seen much for it,but how much hp can it hold to the wheels 250?
Old Nov 11, 2003 | 10:01 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Miles (the guy at diff solutions) is running a 500+hp 427 big block, on at least drag radials on his, and its still holding. but then again you hear of guys with TPI and bolt ons breaking them. like everything else it comes down to no abusing it, and how it is maintaned
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
