Quick will this fit question
Old Nov 10, 2003 | 05:38 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
http://store.summitracing.com/partde...art=MGM%2D6006
Finally found a black powdercoated air cleaner assembly will this fit my 89 305 TBI?
Thanks in advance
Old Nov 10, 2003 | 05:45 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
As long as it isn't higher in the middle than any other air cleaner, it should work.
Old Nov 10, 2003 | 05:47 PM
LedZep's Avatar
I know im talking about the flange size is our TBI 5 1/8 in?
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
Says recesesed base. Im guessing its the same as drop base, so i would say no. go with a non-drop base
Old Nov 10, 2003 | 05:52 PM
LedZep's Avatar
well could anyone point me to another black air cleaner assembly with a non-drop base? I dont want the tacky chrome look.
Old Nov 10, 2003 | 05:58 PM
AJ_92RS's Avatar
If you keep the spacer in place from your old air cleaner, a drop base should work. You just have to be careful about where our coil is mounted.
Old Nov 10, 2003 | 06:03 PM
LedZep's Avatar
Im guessing our flanges are 5 1/8" since noone will answer me haha and I have heard horror stories about mountin the coil and screwing the whole motor over. Any dos and donts here?
Old Nov 10, 2003 | 06:42 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Don't see why it wouldn't fit, just keep the spacer ring in place. I used a drop base for a while with the spacer in place and it fit fine with no interference. I have since gone to a flat base.
Old Nov 10, 2003 | 06:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would buy a regular open elemet and buy an aftermarket black lid. That is your best bet to get the look you want. You will not even be able to see the lower portion that is chrome. And even if that bothers you, you could always paint the bottom. ProForm makes a nice carbon fiber look lid. Look in your jegs catalog under "dress up."
Old Nov 10, 2003 | 07:09 PM
LedZep's Avatar
So last question is there any performance diff in the air cleaner I found as opposed to another? And mine will def. fit no prob right?
Old Nov 10, 2003 | 07:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Any open elemet will perform about the same. One with a K&N will probably yield a few more ponies. That one that you picked should fit. You may have distributor clearance problems. I used a .5" TBI spacer to raise my open element off of my distributor. I did not get a non drop base and that is why I had the problems that i did.
Old Nov 10, 2003 | 07:45 PM
LedZep's Avatar
Ok thank you I will be ordering that one soon unless anyone else tells me something wrong with it. Hope I dont see any problems.
Thank ya for the fast opinions
Old Nov 10, 2003 | 10:26 PM
AJ_92RS's Avatar
Unfortunately nobody can tell you “Yes it will fit your car.”
When new cars are assembled, there is a margin of error that is allowed. If the hood-to-stock-air cleaner allowance is + or – 1/4", then that leaves ½" of variance. Same with the coil-to-air cleaner clearance.
Then you have the margin of error from the company that produces the air cleaner..... do you see where I’m going with this?
All we can tell you is “It worked on my car.”, or “It should work on your car.”
The only way to really find out is try it.
Sorry to ignore your question..... yes our TB is 5-1/8".
Dkelz313
Apr 7, 2016 10:38 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
