Roller Rockers with Vortec Heads?
Old Nov 15, 2003 | 01:56 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
Hi,
can i use Magnum 1.6 Roller Rockers with these modified Vortec Heads? And how much must they be milled down to fit a 305. Ive seen different numbers when searching the forum.
Nebu.
Old Nov 15, 2003 | 09:29 PM
steve8586iroc's Avatar
As long as there self aligning they will work fine. If not you will need to have pushrod guide plates installed also. The machine shop should know how much to take off to get the right cc volume you need to keep the stock compression. If you ever plan to use these heads on a 350 they will have too much compression to run pump gas with a good preformance timing curve.
Steve
Old Nov 15, 2003 | 10:01 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You will need the self aligning, I think they make them but you might have to get a different model (the roller tip ones won't work, they're not SA). With the heads if you use a steel shim gasket, F/T pistons (assuming -4cc) and keep the 64cc chambers with a std .025" deck height, compression will be 9.2:1. You can mill the heads to 60cc, use a composition .041" thick head gasket and compression will be 9.25:1. If you zero deck the block, use a steel shim gasket (.021") and keep the 64cc chambers you're looking at 9.6:1.
Personally, I don't like shaving heads since it reduces the deck thickness on the heads and some aren't that thick in the first place, plus should you go to put them on a bigger motor the compression will be out the roof and you'll be wishing you didn't shave them.
Old Nov 15, 2003 | 11:16 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I'm running guide plates with mine. It's kind of a trade off, as the price of non-self aligning roller rockers are much cheaper and easier to find. Just make sure you use the proper puch rods, or else the guide plates will eat them alive.
Old Nov 15, 2003 | 11:18 PM
vjo90RS8's Avatar
Car: 2002 Z28
www.enginekits.com sells some vortec roller tip self aligning rocker arms for 120. Might want to check them out.
kfoley's Avatar
Car: '85 Z28
Yep, hardened pushrods are a must if running guideplates....
Old Nov 16, 2003 | 07:24 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
I have the CCA-1418-16, Magnum Steel Roller Tip Rockers. They are self-aligning and the CCA-7808-16 High Energy Pushrods 7.195 in. long. (hardened)
So i dont need guideplates and it will work fine with these heads?
Old Nov 16, 2003 | 10:05 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I ran stock pushrods with my guide plates, 6500rpm and all, and not even a scratch on the rods. I've got a set of hardend ones ready to install this winter though.
Old Nov 16, 2003 | 10:40 AM
kfoley's Avatar
Car: '85 Z28
Yes they will work fine.
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
