what are the f/p on tbi
Old Nov 20, 2003 | 07:46 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i installed a fuel gauge on the fuel line and i was wondering at what f/p do tbi work at?there are times it runs at idle at 8-10 but this morning that it wa cold and i had the a/c on for defrost i open the hood and it was at 14 idle ?thats incorrect right?
Old Nov 20, 2003 | 08:28 AM
82Z28NAZ
Guest
Posts: n/a
I'm not sure but I'm thinking around 15 psi at the throttle body
Old Nov 20, 2003 | 08:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the FP really varries, some people stock have tested it at like 8-9psi, others at 13-14.
Old Nov 20, 2003 | 12:03 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well i just installed my gmvafpr and it now runs at 9 psi and wot 15 psi.how come with the stock regulator in park at wot it will stay at 9 -10 psi?and now with the vacumn afpr in park at wot it gos to 15 psi
Old Nov 20, 2003 | 12:05 PM
Dewey316's Avatar
Car: 1990 Camaro RS
that is what the vacume part of the vafpr does, as the vacume drops, it allows more line pressure.
BTW, weren't you running HOG rich? why would you put something on the car that is only going to make that worse?
Old Nov 21, 2003 | 09:21 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
how would it make it worse?
Old Nov 21, 2003 | 10:58 AM
MX265
Guest
Posts: n/a
RICH= too much fuel in fuel\air mixture
More fuel pressure=More fuel
Old Nov 21, 2003 | 02:42 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Absolutely hog rich on the dyno.. VAFPR == more fuel pressure == more fuel == exactly what you DON'T want... everything over 3k was *way* too rich and it fell off the bottom of the graph.. and now it probably falls off the graph at 3k. put the VAFPR on a shelf for now and rechip your car..
Old Nov 22, 2003 | 08:51 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
im gonna keep it on but get a new chip burn
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
