O2 Bypass
Old Nov 20, 2003 | 07:38 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
O2 Bypass
Is there any way to bypass the O2 Sensor and keep the car in open loop? I just put headers on and welded the O2 bung in a spot right next to the crossmemeber (prior to installation and didnt have a chance to test fit)so the sensor wont screw in. The sensor is hanging in through the hole but it reads lean because of the fresh air runnin in through the hole and it sounds like ive got an exhaust leak to the average joe which is embarrassing. Im puttin in a new motor soon anyways and was wondering if it is possible to trick it into staying in open loop so i could put the plug in it and it wouldnt sound like *** because it runs really great until it warms up and goes into closed loop. So any suggestions or input would be appreciated.
Old Nov 20, 2003 | 08:32 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The ecm will go open loop when the O2 sensor goes out off set boundries. For your chip boundry is probably 300mv to 650mv. So if air is hitting it, your probably well below 100mv, so ecm is going to be in open loop. Unpluging the sensor (what you should just do) will cause open loop also.
Old Nov 21, 2003 | 12:07 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
My buddy has an 'H' pipe on his 96 Mustang and what we used to trick the O2 sensors (mustangs have 2) are called 'MIL Eliminators'. Before we put them on (just had the O2's plugged in normally) it slowed the car down due to the retarded timing. (got a 13.9 before, 14.4 after) now that we have those eliminators on, it's hitting below 13.6. I have NO IDEA if/when/how you could get them for your car, but it should be possible. My $.02
Bruce (90RS305)
$750 L98
Feb 1, 2025 02:25 PM
djmarch
May 8, 2016 11:32 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Formula8r89
Sep 22, 2015 04:24 PM
