O2 sensor position
Old Nov 20, 2003 | 09:32 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
O2 sensor position
Hey, i just put hedders on my car and at the shop they put my O2 sensor in the Y-pipe on the passenger side of the engine. Every once in a while, the ses light comes on for a second, then goes back out. I ran the codes and it threw a 44, which says lean exhaust. Could this have to do with the position of the sensor?
Or maybe its bad?
thanks
Old Nov 20, 2003 | 10:21 PM
steve8586iroc's Avatar
Do you only get the ses code 44 when you are driving slow or idling for a while? Your o2 may not be hot enough to keep the ecm in closed loop. Could be time for a three wire heated o2 sensor.
Steve
Old Nov 21, 2003 | 10:09 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Well, not when im driving slow but at a steady pace and fairly low rpm's.
Old Nov 21, 2003 | 10:14 PM
I would check into a heated o2 if I were you.
Steve
Old Nov 24, 2003 | 02:32 PM
Ronny's Avatar
if it goes open loop since not hot enough i dont believe that would throw a code. it would just run open loop till it goes back closed AT TEMP. if anything the open loop A/F may be rich as expected. if you do replace the 02 a heated 02 wont hurt. i was getting a lean code since i was lean at city driving. but that was due to engine mods.
Old Nov 24, 2003 | 03:00 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
There are a number of parameters that must be meet for various codes to set. Some include a timer, ie the ecm expects to go closed loop within X amount of time of a restart, to name but one.
The O2 needs about a 700dF temp to become active. Headers have alot of surface area and radiate alot of heat.
Your cheapest attempt at curing your problem is installing a heated O2 sensor. Thou, there is also the chance that you're actually enough leaner now that you are running too lean.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
corey8084
Sep 17, 2015 02:56 PM
Night rider327
Sep 16, 2015 02:20 AM
