Huuuuuge lag issues
Huuuuuge lag issues
Forewarning: I'm a noob. I was referred here by a friend for my engine problems. I have an 88 Chevy truck with a TBI 305. From my understanding, it's basically the same power-plant as most late 80's f-bodies.
Ok...long of the short...I cannot romp on the gas. If I do, the engine basically stalls. However, if I ease into the gas, it will accelerate. It has been getting progressively worse. My friend thinks it's the timing and/or plugs, but mostly the timing.
As I have little money to spend, and I do mean very little, I need as much info about what is likely to be wrong. Whether I can try and fix it myself, or where I can go, know what I need to know in order to not get ripper off.
Please help. If this shouldn't be posted here, please remove.
Thanks.
Thanks.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
first things to check (cheap)
1) fuel filter CHECK THIS FIRST.
2) cap/rotor/plugs/wires (i personaly am thinking this is a fuel issue, but these are, well cheap)
3) fuel pump (this is my guess right here, i am guessing your pump is heading south)
I'll check the electric components today when I get the chance.
As far as the pump...
Let's just say the environment hates me and I hate dropping and reinstalling my tank. But...if need be...now I know what to do.
Car: 1990 Camaro RS
i would hook a guage up, and go for a drive, i am willing to bet you that the pressure takes a dive when you nail the go pedal.
