Idle Vacuum Values
Old Dec 4, 2003 | 03:44 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Idle Vacuum Values
What kind of vacuum numbers are you guys pulling? I just put my car back together and it's reading around a 68 count (38 KPa). It was at around 220 idleing , and was throwing the high MAP code (33?), but I tightened some stuff up and it went down to what it is now. I have an LT1 cam and a Edelbrock 3706 Intake.
Tony
Old Dec 4, 2003 | 05:47 PM
25thanniversary's Avatar
Car: 92 rs
Engine: 305tbi
Transmission: 4l60e
my vacum is between 9 and 15 inch pounds but i may have some problems
Old Dec 11, 2003 | 03:26 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Anyone else?? WinALDL values??
Old Dec 13, 2003 | 11:53 AM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
WinALDL - 26.8 kPa on startup. It was at about 1200 RPM. I don't know if my engine is a good one to base values off of though
220 kPa sounds kinda high
Old Dec 13, 2003 | 02:20 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Haha, yeah the 220 is a little high! Actually that is the raw value, not the value in KPa, I'm not sure of the conversion. I tightened some stuff up and double checked some hoses and it's down to about 35 Kpa at idle, not too bad. I think because of the cam and intake it'll be a little bit higher than the stock "cam" (if you can call it that, it's more like those cardboard tubes in paper towel rolls, no lift at all!)
83 Crossfire TA
Jan 3, 2016 01:26 PM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 2, 2015 02:01 PM
mdtoren
Aug 23, 2015 12:52 PM
