WARNING n00b Question (what is a TBI)
Old Dec 22, 2003 | 09:09 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Just wondering here. I was told my car is a 305 TBI (Throttle Body Injected). I was curious to see how it works so I went to www.howstuffworks.com and typed in Throttle Body Injected and the page that came up was talking about carberators. Is TBI the same thing as a carberator?
Old Dec 22, 2003 | 09:23 PM
ammo_dogg's Avatar
Car: 92' Camaro
carb uses a bowl and float to distrubute a corret amount of gas. TBI is like a fuel injected carb. instead of a bowl with a float the lowers to allow mor gas in. TBI has a computer tell it when to injct the gas diretly into you your intake manifold. So a carb is more of a manual type.
Old Dec 22, 2003 | 09:35 PM
ThraxXx's Avatar
Computer eh!...now your talkin my language. We recently burnt a mod chip for my Tempo that fixed the car from running rich "due to intake and exhaust mods" which caused the car to run more efficiently as well as more power. Is this option also avail for the computer on my Trans Am?
Old Dec 22, 2003 | 11:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes it is. You can really improve by changing from the stock prom. I would learn up a bit more on what makes a TBI run before you go off and start to tune. But on the good side, it is never to early to learn how to burn chips for these cars.
Old Dec 22, 2003 | 11:05 PM
vjo90RS8's Avatar
Car: 2002 Z28
go to the DIY PROM boards, there is SO MUCH information and it is amazing how much people have done for thirdgen F-body computer tuning.
Old Dec 23, 2003 | 04:19 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
One thing I really enjoy about TBI (minus obvious inferiorities to TPI) is most Carb parts work with them! I have an Open Element air cleaner (see webiste) originally designed for a carb and it gave me a good boost in throttle response and increased top-end acceleration. Only cost me $30 and was a PIECE OF CAKE to install...
Bruce (90RS305)
Old Dec 23, 2003 | 08:11 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Bruce (90RS305)
I loved the instant power I had with my open element install. I still say that gave me the biggest SOTP feeling over any of my other mods. Well since I am putting in a new cam that may all change
Old Dec 23, 2003 | 11:32 AM
ThraxXx's Avatar
By open air element you mean by removing that black saucer thing and the snorkel attached and having the filter exposed? I wonder if I can get that at Canadian Tire.
Old Dec 23, 2003 | 03:36 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Actually, you showed up at just the right time. I recently released a complete .ECU as well as a massivly expanded tunercats definition file based off of the ECU file for the '88 8063 tbi ecm so theres no need to use tuner cats and their somewhat aneamic definition file. Although id still recommend checking them out. Their software package is very nicely done. Definatly worth the money with a good tdf available. Have a look .
Old Dec 23, 2003 | 03:40 PM
Car: 88 Camaro SC
Engine: SFI'd 350
btw, i love that license plate!
Old Dec 23, 2003 | 08:58 PM
ThraxXx's Avatar
Thanks...those are the plates that are going on my t/a
Old Dec 24, 2003 | 11:08 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
...minus obvious inferiorities to TPI...
I'd like to quote a source of info I got while researching the install of TBI and/or MPI onto my Jeep engine...from the guy that runs CustomEFIs.com....(sung to the tune of "Here Come The Clowns")
"TBI is in no way inferior to MPI or TPI." This is a DIRECT quote.
No $hit. He actually told me that. If I still had my Texas-state e-mail address, I'd send you a copy of the e-mail he sent to me. Do I believe it? Hell no I don't. The differences are immediately obvious to anyone.
Anyway...cool plates. Mine say TIPOVR (on a 1980 Jeep CJ7).
BTW...the GM TBI install on the Jeep engine is going pretty much as planned. Just a few more little parts and it'll all be done. I knew this would take a while...can't wait to drive the results!
Merry Christmas and Happy New Year to all on the TGO board!!
Old Dec 25, 2003 | 01:45 AM
90RS305's Avatar
I was actually reffering to TPI vs TBI on ThirdGens. A stock TPI 305 will blow the doors off a stock TBI 305. Heck, that was for the most part the only diff. between the first IROC's and RS's. I know there is no inferiority factor in most cases though. As far as TBI is concerned on a whole it's more upgradeable than a TPI, and for a lot cheaper too. So yeah, shoulda probly elaborated a lil' more on the first post!
Bruce (90RS305)
Old Dec 25, 2003 | 02:58 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Here's a list of sites that will tell you (and anyone else who wants to know) anything and EVERYTHING you'd ever want/need to know about TBI, L03's, and the 3rd gens they came in!
What Is TBI??
TBI Diagram. The Real Story of The L03!
How to get the most out of your 5.0 liter L03 TBI fed V8!
Modifying Your ThirdGen F-body! (the basics)
Old Dec 25, 2003 | 04:10 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Are you saying that the only difference between these engines is the TPI and TBI? If so, that's way off. The reason the TPI 305's were faster than the TBI 305's is because the TPI cars had better heads, better cam, more free flowing exhaust, and I believe the Prom's in the TPI cars had a bit more aggressive timing tables and a more performance oriented tune. That is why the TPI cars were faster.
Old Dec 25, 2003 | 09:56 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
I wasn't trying to flame anyone here on TGO...I WAS flaming CustomEFIs.com, however.
I could tell you the whole story, but the long and short of it was that I was looking into a custom built MPI system for my Jeep based on the Edelbrock Torker manifold. He helped out some, but he was fairly vague in what he would and wouldn't say...unless I sent him $25 for a subscription to his website and archives. I will admit that he stopped me from putting together a bunch of mismatched parts that would have been a large waste of time and money. Armed with what I know now from this board and past experiences, I could probably build the system the right way now and I may in the near future once I get the thing (Jeep) up and running with the TBI system.
It seemes like he was REALLY trying to sell me a TBI system back then...he hawks TBI for Jeeps at $895 and up...MPI for an AMC V8 will run you $1600 or more depending on what you want.
I firmly believe that TPI has a more efficient fuel delivery manner than does TBI. The "wet manifold" concept leaves too much chance for fuel puddling in the runners. TPI effectively eliminates that problem.
Old Dec 25, 2003 | 10:20 AM
Car: 88 Camaro SC
Engine: SFI'd 350
your absolutly right about that. Thats one of the only real advantages to a stock tpi over a tbi. Its a dryflow system. Fuel puddling has always been a problem for me.
Old Dec 25, 2003 | 05:48 PM
dennis6's Avatar
Car: 1991 Camaro RS
TBI is like a 2 barrel carb, nothing to brag about. If you want a fast TBI car get a 4barrel holley setup.
Old Dec 25, 2003 | 07:47 PM
90RS305's Avatar
Guess I didn't elaborate enough in my second post as well. I was just trying to say it is a lot easier to work with a TBI as far as playing with it is concerned, but with a stock TPI your starting out with a more efficient setup. Trust me, I can make my way around a TBI no problem, but when you get into cfms and ratios and the like I'll just nod my head politley. I should be the mod on this board as well soon but that just to keep you jokers in like (j/k )
I know, and I agree with you too...
Bruce (90RS305)
Old Dec 25, 2003 | 09:37 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
dennis6, no flame intended here, just my opinion...
I'll politely disagree here. The 4V Holley set-up is cool, but you may as well bolt a POS 4V Holley 4160 carb in place of the 2V TBI unit. If you look at the flow of a set of 305 or 350 heads, you will see that they can't flow that much air and fuel. The 4V can actually provide too much flow for the engine IMO. I can't remember the website, but there is a site that compares flow data from various sets of heads and the OEM GM V8 heads are pretty much at the bottom of the pile IIRC. I am not flaming here, just speaking an opinion...I have a set of OEM heads on a 1979-model AMC 360 that (right out of the box) can outflow a set of OEM GM V8 heads. Now that they are ported and polished on top of a bored-out 360, I still can't justify that much flow from a TBI. Do the math and you just may find that about 580cfm is just right...give or take a few for differences in flow characteristics.
As for the 2V carb, I had a Motorcraft 2150 on this engine before I went to a 4V carb and eventually the 2V TBI. That "little" carb fed my engine with PLENTY of fuel and it would do it at some really weird off-camber angles. It was rated at about 550cfm. Why did I go TBI on my Jeep engine? In a nutshell...just to see if I could do it. Now that I have it, there is no way in hell that I would go back to a carb'd engine. That 360 got a whole new outlook on life with the Holley ProJection, even though I hated it 'cause it wouldn't stay tuned right. Now that I have the GM TBI system all but running, I am more than eagerly awaiting the results of my project.
Use the 4V TBI on a BBC and THEN you have done something worthwhile IMO...
Again, no flames meant and I hope I didn't insult anyone.
Old Dec 26, 2003 | 12:33 PM
dennis6's Avatar
Car: 1991 Camaro RS
On a 305, you are probably right. A 2 barrel TBI could feed the engine. A 2 barrel carb probably could also.
On a serious 350 or larger engine, I tend to think the 2 barrel TBI unit would choke the engine. Holley makes different sizes of the 4 barrel unit to accomadate smaller engines.
Old Dec 26, 2003 | 07:16 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Well, it IMO depends on your definition of "serious". Like I said before, I am running an AMC 360 +0.030" bore (works out to almost 370cid) with a set of gasket-matched/ported/polished heads and an Edelbrock Performer AMC intake (dual-plane for low-end grunt). My cam specs are something like 272/288 adv. dur., .472/.496 lift @ valve, 114 deg lobe CL. My ignition is a digital racing ignition. I run 2V TBI and it works REALLY well. I haven't seen any choking of that beast yet and it dynos @ almost 390hp and 410 lb-ft. In fact, it runs MUCH better than it did with the 4V Holley 4160 carb...I can't wait to test out the GM TBI. It seemed like the carb was dumping raw gas down the manifold. It smoked like crazy with a BRAND F'N NEW block and heads even after the break-in period. I rebuilt the carb twice to no avail. The Holley 2V ProJection cleaned it up and really helped, but it wouldn't stay tuned. That's why I hated it...that and the fact that it smoked TWO ECM's for no apparent reason. If I had so much as a wind direction shift, I had to re-tune the MAIN and ACCEL maps. Season changes took a while to tune for...worse than a carb IMO.
I'll agree with you on the fact that if you are trying to run 500hp from a SBC engine at 6800rpm, you probably do need a 4V TBI. A 383 stroker motor could probably use a 4V set-up. A BBC could definitely benefit from a 4V TBI. I may be reaching here, but IMO this is where the VE tables start to come into play. If the engine can move more air more efficiently, it needs more flow from any kind of aspiration...carb, TBI, MPI, TPI, etc, etc...If you sincerely think you need a 4V, look at your log results...or just put a 4V carb on it for a test run to see how it runs. With a 305, you may find it bogging out at low end rpms and your high end performance will probably degrade likewise. Too much gas can be just as bad as not enough. Get a copy of Desktop Dyno 2000 and see where your peak VE is with your engine config. If you don't want to spend the $45, email your engine specs to me and I'll run 'em for you...I might even be able to post a screen shot of the resulting tables and graphs.
Old Dec 26, 2003 | 08:39 PM
dennis6's Avatar
Car: 1991 Camaro RS
Check out 5-7kids expierence with carbs. I think you just had a bad carb. Also check out holleys site for recommendations on carb size. Alot of people have went from 750 CFM VS on 305s to mechanical secondary carbs and found no bogs and a increase in track times. Vacuum secondary carbs are for towing, not for performance.
A good holley double pumper or Speed demon would probably change your mind on the 2 barrel vs 4 barrel thing.
The only real way to settle this would be to properly tune a mechanical 4 barrel carb and dyno it on your engine, and compare it to your 2 barrel TBI. A better comparison would be to use a commander 950 ECM with a 2 barrel unit and a 4 barrel TBI unit.
Old Dec 28, 2003 | 01:06 PM
ThraxXx's Avatar
What Is TBI??
Thanks for the info man. Greatly apreciated. I need to get all the knowledge I can before the summer when the mods start comin in.
MustangBeater20
Oct 29, 2022 09:20 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
