Anyone see these aftermarket TBI Spacers in JEGS?
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I was looking through the new JEGS catalogue and came across Throttle Body Spacers (part #555-15412) says, "Tests have shown a 10% increase in torque, 15% more horsepower and 8% better fuel economy." ALSO, there is a TBI Fuel Injector Spacer (part #555-15410) for 86-95 4.3, 5.0, 5.7L that reads, "This spacer raises the injector housing 1/4" above your throttle body and allows 15% more air flow into your engine." Has anyone seen these BETTER YET has anyone used these on the LO3???
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have a .5" spacer from turbo city. The only reason why I have it is so that my drop base open element will clear my ditributor. You will not see the power they claim. The injector spacer is a good idea and helps unshroud the intake bores of your TBI a bit by raising the pod a little higher. Plus, the jegs spacers are 1" and you will have throttle linkage problems. Mine barely reaches with only a half inch spacer. Also 1" and you will have hood clearance problems. With my spacer and Edelbrock TBI intake (.25" tall than stock) my hood comes right down on top of my open elemet. If my spacer were any higher the hood would not close. I also think that my spacer is contributing to my rough idel because it has the two bores siameesed. This creates a dead open spacer between the intake surface and the TBI unit itself and cannot be good for smooth air flow.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Wow Shifty, sounds like it's doing more bad than good! You should switch to a dual-snorkel setup. Sounds like with your setup it could be really bennificial!
Bruce (90RS305)
Bruce (90RS305)
Car: '90 RS
Engine: 377 LSX
Bruce (90RS305)
Bruce (90RS305)
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by ShiftyCapone
Just like any open element they get poor when it gets really hot out. Other than that they perform rather well.
there are ways to keep colder air directed at it. Joined: Feb 2001
Car: '90 RS
Engine: 377 LSX
Originally posted by Dewey316
the key here is not letting it get hot
there are ways to keep colder air directed at it. Senior Member
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
ok call me crazy but i just got this thought b/c of what u and i did shifty. If you could get the linkage to reach you could run the 2" element like i bought and it should clear, basic math, 1" spacer +2" element = 3" just like my element. but if the spacer doesn't help i guess there's no point, just was thinking about that option
Car: '90 RS
Engine: 377 LSX
Very true, but for your average 3rd-genner who does this as a first mod they will learn realy quick once june rolls around.
)Bruce (90RS305)
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
I got both the 1/4" injector spacer and 2" TBI spacer from jegs. They both clear the hood perfectly. However, I use a 2" (I think) drop base open element and keep that sh!tty ring thing on the tbi so it sits straight. Looks awesome and no hood clearance or throttle linkage clearance problems at all. It's feels a lot faster too cuz the throttle pedal is nice and stiff now.....I love it. And it does increase fuel economy. I went from around 15mpg, to about 18-19mpg city. And that was JUST with the tbi and injector spacers, I changed nothing else. The power increase is noticable too down low, but you dont' feel it pull too much harder about about 4000 rpm. Still nice though....gotta love torque.
why did my throttle linkage reach fine and people with only a 1" spacer had problems.....??????
Car: '90 RS
Engine: 377 LSX
HA! Why wait untill June? It's New-Years Eve and us Arizonans STILL feel comfortable in shorts/t-shirt in the middle of the day! lol, around April here is when open elements start to be anti-productive... (so why do I still use mine?
Bruce (90RS305)
)Bruce (90RS305)
Car: '90 RS
Engine: 377 LSX
Anyways to stay on topic I saw in the jegs catalog a whol enew slew of spacers. I think there are about 5 companies that make them now for 2bbll TBI applications. Even Vortech makes them now.
Guest
Posts: n/a
Bruce (90RS305)
)Bruce (90RS305)
Originally posted by 82Z28NAZ
because it's still better than the choked up stock LO3 air cleaner
and took it to the track to see what it could do. Slowed me down .4 seconds. The thing I like about it though is I can still feel my car accelerating after 4,500rpm's!
This time of year here, even though it's still not that cold, hopefully it'll do my some good. Bruce (90RS305)
Guest
Posts: n/a
I don't have an open element but...
I have a dual snorkel with a larger K&N in it that holds the lid up about an inch. I don't have any of the ducting in place so it does suck in engine compartment air. Even with this, for the first time it pulls to and past 4500 RPM's where, before, it would shift just shy of 4000 RPM's. Of course it's still the stock, sloppy, and limp 700 R4 shift
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Hey Shifty, with that new manifold, do you have to use the .5 inch spacer? I really dont want to use a spacer, so I'll even buy the manifold to get around using one.
Car: 1992 Camaro RS
Engine: 305 TBI
not shifty but i do believe he is planning on using the spacer, since his air cleaner is a drop base and wont clear the dist. but if he has changed his mind in the last 2 days i dont know.
Car: '90 RS
Engine: 377 LSX
