where to get injectors?
Old Jan 7, 2004 | 02:12 PM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
i need new fuel injectors for my 305 tbi, where do you recomend i aquire these items?
Old Jan 7, 2004 | 02:21 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
He-he. They sell 'em at AZ, but I'm cheap.
Pull-a-part has a yard full of them.....and wrecked cars were usually running when they wrecked!
Old Jan 7, 2004 | 02:48 PM
p0rk's Avatar
Car: 87 firebird
Engine: 305 tbi
Transmission: 5spd
thanks, i just dont wanna get another leaky one
(assuming that is why i have trouble starting every now and then)
Old Jan 7, 2004 | 03:10 PM
Car: '89 Formula
Engine: 305 TBI
If you decide to go to a junkyard for it, I have a bit of advice.
All you need is a "star-bit" screwdriver(T-20) and a flat tip screwdriver to pry the injector out.
Find a car that looks as though it was well maintained and, preferably, wrecked in the front.(this means it was running well when wrecked )
Now, remove the top of the TBI. Once you pry out the injector, be sure there is no trash in the fuel resevoirs. If the resevoirs are clean it should be a good injector. Look closely at the "O" rings for damage...If they appear in good shape, hang onto them!
As far as leakage in your present ride....I'd almost bet its' your "O" rings and not the injector.
Its' been my experience that I can buy several injectors at a junkyard for what one will cost at AZ.....and the Safari is always fun!
Actually....I'm 4 good ones on 4 tries, so far!
Happy hunting!!!!!!
Old Jan 7, 2004 | 04:33 PM
Ronny's Avatar
gmpartsdirect.com has decent prices. what is going rate for used ones? i have a couple that were worjkking fine when i replaced with 90 lbs. they are mismatched from crossfire setup.
Old Jan 7, 2004 | 04:59 PM
Car: '89 Formula
Engine: 305 TBI
The last couple I got were under 10 bucks......seems the folks around here don't know what to call them!
In reality....I don't know what they are really worth......I just know what AZ charges for them!
Old Jan 7, 2004 | 05:43 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
AZ can actually be a really cheap place to buy parts (minus A/C). I used to work for Chapman Chevrolet and getting parts for my Camaro WITH my discount was friggin DIRT cheap. (All you have to do still is just go to a parts depot and tell them you work at another one of their dealerships, I didn't tell you that!)
Bruce (90RS305)
Old Jan 7, 2004 | 06:17 PM
Pat Hall's Avatar
I have to agree with Fairly Strange that it's more than like just your o-rings causing the leakage. I thought I needed new injectors for mine at one time, and it just turned out to be bad o-rings. I'd make sure this isn't your problem before spending any money on new injectors.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
