IAC questions
Old Jan 7, 2004 | 06:04 PM
vegascmc's Avatar
IAC questions
I have a problem with my car's idle, when I first start it cold the idle jumps up and down. If I give it a little throttle for about 1 min the idle seems to steady down and once warm idle seems fine. Also running down the road at a steady throttle there seems to be a miss or stumble at irregular times. Using Winaldl I have noticed that the IAC #'s run about 140-80 for the first minute or so then starts a slow descent down to about 30 when warm, but every once in awhile it jumps up to 120 and then slowly goes back to the 30's over about a minute. Hope someone can help me with this it is driving me crazy. thanks
Old Jan 7, 2004 | 09:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id suggest cleaning the IAC for starters. See if that helps. An IAC that lags behind can cause problems.
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
