Crossfire injection???
Old Jan 15, 2004 | 07:35 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
What is the difference between CFI and TBI? Or is there a difference..
I tried going to howstuffworks.com and looking it up but all it shows me is stuff like "why doesn't my car start in the winter" and junk like that.
Any help on this topic would be greatly apreciated.
Old Jan 16, 2004 | 08:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
CFI uses 2 one barrel throttle bodys with one injector in each.
they're "across" from each other..
TBI as we think of it is a single 2bbl 2 injector setup that looks like a carb..
athough technicly, since the CFI has the fuel injected into the throttlebody, they're both Throttle Body Injected... and thats why they're both on the TBI board.
heres a CFI:
Old Jan 16, 2004 | 08:10 PM
ThraxXx's Avatar
Are there benefits to running a CFI Setup for a TBI?
Old Jan 16, 2004 | 09:18 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
both arent exactly prime canidates but the tbi is definetly the better way to go... crossfire (anyone else get reminded of the game? ) has small ports, not to mention the ecm's are probably hard to tune, i dont know for sure im just guessing. also there is 0 aftermarket for the crossfire... its just not a smart budget wise choice to go... there was some kinda manifold someone designed with the crossfire set-up but i cant find it... some guy on here said he put it on a 400 sbc and had great results... overall though it seems to be one of those things people improve only because someone else says it cant be done... no one chooses a crossfire because its better.
Old Jan 19, 2004 | 08:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
the aftermarket manifold is the X ram... theres not a huge aftermarket, but there is one, and a loyal following.. keep in mind that the C4s had CFI alot longer then the Fbodies....
tuning is the same.. you can even run the 747 TBI ECM with the CFI if you wanted... they're the exact same thing except that the two barrels and injectors are across the manifold from each other instead of next to each other..
NZKnight
Oct 15, 2015 02:47 PM
Tweeks25
Sep 17, 2015 08:04 AM
edoff13
Sep 11, 2015 03:55 AM
