Timing
Old Jan 19, 2004 | 02:36 PM
1989k5's Avatar
Timing
I have a 89 TBI 350. I have been playing with the timing and I noticed that when I put the light on it (with the ESC disconnected) the timing will occasioncally jump like 20 degrees and the fall back to the base timing. Everything from the timing chain to the distributor to the plugs is new within the last few months. What could be causing this?
Aaron
Old Jan 19, 2004 | 02:44 PM
Brent's Avatar
How fast is the engine running while checking timing?
The module has a built in advance curve that activates, when in ESC bypass, based on engine speed (can't remember the RPM).
Old Jan 19, 2004 | 02:59 PM
1989k5's Avatar
I'd say around a 1000 rpm.
The timing jump only lasts for a second or so, just one or two flashes of the timing light, then it goes back to base timing. A few seconds later it will jump again.
AW
Old Jan 19, 2004 | 03:22 PM
Brent's Avatar
I'm betting you are activating the module advance curve then.
If I'm correct then raising the RPMs to 1100-1200 should result in the timing advancing to that higher level and staying there.
It should be idling around 500rpms when checking timing.
Old Jan 19, 2004 | 04:06 PM
1989k5's Avatar
Ill try lowering the idle
Old Jan 19, 2004 | 04:38 PM
1989k5's Avatar
I adjusted the idle and it had no affect.
Aaron
Old Jan 19, 2004 | 05:40 PM
Brent's Avatar
No affect on what? The timing or idle speed?
Does the timing advance when you speed the engine up? Try as much as 2000 rpms.
Old Jan 19, 2004 | 07:47 PM
1989k5's Avatar
Idle dropped, but the timing problem continued.
Old Jan 19, 2004 | 11:41 PM
Charlo's Avatar
Intermitten spark jump from other cylinder triggering your inductive timing light?
Maybe even a bad timing light?
Charlo
Old Jan 19, 2004 | 11:45 PM
1989k5's Avatar
I thought about that too, but you can hear the engine miss when the spark jumps.
Old Jan 21, 2004 | 01:22 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Rig up a vacuum gauge and check manifold vacuum...I almost guarantee you'll see a drop in vacuum when the timing flucuates. As to the cause? Some kinda misfire/incomplete burn I suppose, is most likely.
Old Jan 21, 2004 | 04:07 PM
1989k5's Avatar
But what would cause the misfire?
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
