84 305 H.O heads on 91 305
Old Jan 22, 2004 | 02:28 PM
91NiteRida''s Avatar
Car: 1991 Camaro
Hi,
I was wondering if 84 305 HO heads will fit on my 91 305...I have the heads off because im changing the head gaskets and was wondering if these head would fit.All and any info will be greatly appreciated.
Old Jan 22, 2004 | 02:34 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yes, but you will either need a new intake manifold, or drill yours out to fit the center two bolts.
also, you will need to drill out the pushrod guides, or use non SA rockers.
HTH
John
Old Jan 22, 2004 | 02:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Definatly want to drill out the guides with SA rockers. My 305 came from the factory with heads that had slots and SA rockers. I can easily see where the pushros have been dragging on the guide slot.
Old Jan 22, 2004 | 02:56 PM
Car: 1991 Camaro
Thanks for the help guys....Ill just re use my old heads since i located an edelbrock intake for my camaro.
Old Jan 22, 2004 | 09:32 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
This is kinda off topic, but what is the difference between SA and non SA rockers?
You'd also need new valve covers, but im assuming they prolly already have them on the heads seeing as they arent new.
-chuck
Old Jan 22, 2004 | 09:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Self Aligning rockers have little rails on each side of the rocker tip that keep the rocker centered on the valve stem face.
Old Jan 22, 2004 | 09:44 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Originally posted by 91NiteRida'
Thanks for the help guys....Ill guy re use my old heads since i located an edelbrock intake for my camaro.
those ho heads are significantly better than your stockers. if you have the heads off the car, there's no better time to upgrade. drilling out the holes in the intake and in the pushrod guides isn't that big of a deal. if you already have those ho heads, you should swap them on.
if you don't already have those heads, look for a set of 081 heads. they come off of 87 and newer lb9 305 tpis, flow a lot better than what you have and will bolt right on without your having to drill out anyhting.
Old Jan 22, 2004 | 10:21 PM
Car: 1991 Camaro
I think i will go with the set of 081 heads because the H.O heads are used and the 081 heads i can get brand new "used"..Is the 081 heads the last 3 digits casted on the heads?If so i can get those for 90 bux a piece brand new with trade in of my old heads at a place called Heads Exchange.If i get the 081 heads,they will bolt up without a problem and will re-use the stock manifold and push rods?Sorry for all the questions and if i had the money i would go the 350 route but i gotta deal with what i have.Thanks once again for all your help.
Old Jan 22, 2004 | 11:47 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Yes the 081 heads should bolt right up no problem. So I would definetly go that route if I were you good luck.
Old Jan 23, 2004 | 12:03 AM
Car: 1991 Camaro
Thanks IROCAHOLIC...You said they should fit, but I dont like the uncertainty .Is 081 the last 3 digits in the casting numbers on the head?
Old Jan 23, 2004 | 12:09 AM
Engine: L03 305 TBI
yes, 081 are the last 3 letters, and yes, they will bolt up with no problems. that's a good price ... i'd get them
Old Jan 23, 2004 | 12:36 AM
Car: 1991 Camaro
Thanks for the info guys.Ill be giving them a call tomorrow.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
