Quote:
Originally posted by joshwilson3
I plan on cleaning my TBI unit. In the Haynes manual, it shows that there are little filters on the tips of the injectors. Does anyone know where to get these at? Maybe a part number or something?
There are two filters on each injector. The other one goes into the side of the injector and is about 1/8" in diameter (a little tiny hard to pick up and handle kind).Originally posted by joshwilson3
Rebuild kits (about $35 US) include the filters. For just the filters try injector rebuild houses, Lindertech, Rich at CruisingPerformace, are two examples.
RBob.
You can buy the kit as you have pictured(less injectors) at just about any auto parts store. I got mine from NAPA for under 40.00.
I got a kit at Pep-boys about 4 years ago. BorgWarner brand IIRC. Was very complete, filters, gaskets, base gaskets (2 actually). Was under $40 US.
In the pic you posted the filters are in the upper right corner. The little dots are the ones that go into the side of the injectors. The two rods are guide tools for helping at re-assemble time.
RBob.
RBob.
I have bought 2 of these kits in the past week @ Advanced Auto Parts. It comes with the injector screens and the fuel pressure regulator diaphram. It cost me $40.56. Comes with all gaskets, o-rings, and seals. Plus the hard plastic o-rings that seal the fittings on the back side of the throttle body.
Did it come with the diaphram thingy as pictured in the upper left hand corner of the screen?
I believe that it did.Originally posted by joshwilson3
RBob.
I still have the old box in my shop, I will try to post the number this evening.
I dont mind getting it for you but why dont you just call or stop by the parts store yourself?
We have a NAPA store and a Parts Plus store here. NAPA has Echlin and Parts Plus has Borg-Warner. I have rebuilt several throttle bodys and buy from both places. The Borg-Warner just happens to be what was in the shop. Any parts store should be able to cross reference the Borg-Warner # over to whatever line they carry.
the 97-724 GP sorensen kit isnt bad, it came with everything for the TBI and then some. metal rings, filter screens, all rubber, 5 gaskets, injector pod gasket, diaphram, thrd sealer/locker, and 2 screws. I put this on mine it worked fine.
