Engine is not what it was suppose to be
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
I had seen a few sights on tuning TBI etc, but as the motor is not close to where it's suppose to be because of misleading sales clerk before I left W. Cost, I have wanted that fixed right last year.
I got an email that is being done now, cleaned carbon off Federal Mogul H345NP40 pistons, 67cc with a .015-.020 gasket should give me a better compression above 9.0:1. Quench should be 40, Edelbrock 3704 Manifold and from sights I saw on tuning through ALDL, some said winALDL may not work and others said it will work on settings if I play with it. They also suggested a lap top to tune it under loads etc and make small changes, but I hope it will give me read outs at first to see where issues may exist. Turbo City made a chip a year ago when I was putting motor together based on what I was doing to motor, basically more advance and a modified TBI setup.
Finer tuning, should make it come alive as I don't have funds for a Command 950.
Sites I stubled through are as follows:
http://www.diy-efi.org/gmecm/papers/...html#tablelist
http://www.tunercat.com/
http://w1.601.telia.com/%7Eu60113744...dl/winaldl.htm
http://www.winaldl.webhop.net/
http://www.cfm-tech.com/
I may end up selling Edelbrock 3704 manifold and Elite Center bolt valve covers depending on if they fit torker heads or not as well as 1.6 comp roller rockers, but I planned motor to have a least 9.0:1 compression and from what I read, over 9.25:1 with cam helps even more. Not sure about manifold as I may long gate middle bolt hole to fit, just depends or go to Holley 300-418 with TBI adapter. Heads are first then go as I need and so motor's got 9000 miles on HYP F.M Pistons and Moly rings, now hopfully finally done right!
Mean while, I had a open-42 code, found by chevy error sites and using paper clip to get code and multi-meter, which ended up being a pain and MSD coil burnt out taking out modulator/pickup. Fixed, or, MSD/Proform replaced Coil/Distributor and still got a code 42, which was track down to wire short/brake between firewall when I checked at computer end and distributor end of wire, now heads and finally, like pulling teeth, I hope to get some idea of tuning Lower 93 GMC truck better.
Especially after finally get the email as follows on heads:
Hi Michael,
I just want you to confirm that you will be happy with a pair of 083 cylinder heads to be sent out to you to replace your existing pair of 217 heads.
Please confirm ASAP so that they can be shipped immediately.
Hi Michael,
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I think you need to start putting actual questions in your posts. What kind of replies are you looking for to this??
Response to question
This was a response to question, as other site I work on you post, others answer or ask more involved questions and you COMMUNICATE.
He had/or she had asked about truck and trying to decide around ALDL question and I responded.
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
Re: Response to question
did i miss something is he refering to him self as a thrid person or is this somthing he copied from somewhere eles
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Hopefully your post found its way to the person that was asking the question........
Oi.
S-D
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
rather than starting independant topics that confuse the heck out of people..
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
:werd: thats nice i've been to all of those site myself. So what was your question
eightsixseven
Dec 16, 2024 01:50 PM
NinjaNife
Aug 23, 2015 11:49 AM
