Injectors for TBI
Car: 1992 Camaro Heritage Edition
Engine: 305 TBI
Injectors for TBI
Hi, I'm looking for some injectors for my 305 TBI. I recently found some for a 350 vette engine. I was wondering if these injectors would work with my TBI. Also if I did put them in would they mess with my computer or anything else? Thanks.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you're car is stock they will supply way too much fuel. Get some stock 305 injectors. Why are you getting new injectors?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Engine: 305 TBI
I'm just looking to get a little more power. I'm adding a fuel pressure regulator, bored out throttle body, and I wanted to get some better injectors also. What ones would be best just for a little increase?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you are getting a FPR, why would you need new injectors? there really is no performance gain to be had. you make the most power at the proper AFR, not by dumping in fuel. giving it more fuel can be couter productive, considering that these cars ran pretty fat from the factory.
Car: 91 RS
Engine: LO3
what they said. dont do it! you will notice nothing, if not poor mileage, youll junk your converter, and be changing your plugs every 2000 miles. take it from someone who has made that mistake.
Car: 1990 Camaro RS
yes, you are not going to change the air flow of the engine much at all, adding fuel WILL NOT get you any more power. you have to add both air and fuel, in the right mixture to get power. without opening the heads/cam/exaust up, you are not going to get any more air into the engine. adding more fuel, takes up space, give you less air, and a less than ideal air:fuel ratio. like i said, it will be counter productive.
to quote BronYrAur
to quote BronYrAur
