air cleaner for 454 dual TB recommend?
Old Feb 4, 2004 | 11:26 AM
Ronny's Avatar
need a referral for an air cleaner for above. part # aftermarket? first i purchased was a standard 3 inch but it dropped down about 1/2 inch or so and hits the throttle shaft lever. was not a drop down type but did. injector pod is 2 & 3/4 inch from lip of TB so 3.0 inch is minimum. do all air cleaners typicaly drop down a bit over lip of carb/TB like a 1/2 inch? i have a clearance issue with hood possibly but not sure have not yet got that far.
Old Feb 4, 2004 | 02:19 PM
Ronny's Avatar
tt
Old Feb 5, 2004 | 01:09 PM
Ronny's Avatar
tt
Old Feb 6, 2004 | 01:18 AM
steve8586iroc's Avatar
Ronny, if the only thing that hits the air cleaner base is the throttle shaft lever, you might try relieving that area with a good curved surface and a hammer or if you know someone with a hydrolic press, well you get the meaning. Might be worth a try.
Steve
Old Feb 6, 2004 | 10:47 AM
Ronny's Avatar
the interference area matches up with the air cleaner element bottom. so that recontour wont work for 14 in air cleaner. first one i recd was a comp cams polymer plastic unit and interfered as it is about a 3/4 drop. second one one is a proform (recd today)and it dropped 1 inch BUT has a relief area both sides for what i dont know. may match up/ may not.. will know tonight. any other ideas?
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
