350 caprice swap
Old Feb 8, 2004 | 03:29 PM
Berlinetta's Avatar
350 caprice swap
could i take the TBI 350 out of a caprice, along with the appropriate sensors and PROM, drop it into my camaro and have the car still pass emissions?
I ask cause im not sure how similiar the emissions equipment is between the two and whether or not the caprice chip would control my camaro's emissions equipment properly. Of course, i will eventually upgrade to street legal headers, etc.
Old Feb 8, 2004 | 07:16 PM
Berlinetta's Avatar
come on guys, someone here knows the answer
Old Feb 8, 2004 | 09:12 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Yes you can pending you tune the PROM right and retain the normal emmsions stuff. The LO5 is by no means a performace engine and emmsions shouldn't be a problem as long as you run a cat and do the stuff I just mentioned. A search on this matter will yield you trillions of posts.
Old Feb 8, 2004 | 09:43 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
350 tbi caprices pass emissions dont they? I think all the emissions stuff is the same in both cars. Just compare them and see if they arent take whatever is not in your car and put it in it, then youll be set. Good Luck for their is a long road ahead of you my friend.
Old Feb 8, 2004 | 09:47 PM
Berlinetta's Avatar
lol, why the sad comment about the long road ahead?
Why would i have to tune the prom? If i use the stock caprice cop engine and put in the stock chip, it shouldn't need any tuning, should it?
Old Feb 8, 2004 | 11:09 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Yeah it should work if you get everything you need fromt the car ( prom, knock sensor, Esc module, and injectors) you should be fine tuning wise. I forgot you were keeping it pretty much stock I was thinking about the long road I had when I did the swap, but I got my L05 from a truck and I didnt know what all I needed to get mine to work because I wasnt using this site when I did my swap a while back. So it should be pretty simple for you . Good Luck.
Old Feb 9, 2004 | 10:08 AM
Berlinetta's Avatar
thanks guys, im giving the car to my brother so thats why i wanna keep it so simple. I dont want him to have too much fun.
midge54
Sep 2, 2020 07:13 PM
xkingcodex
Feb 12, 2020 07:43 PM
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
theshackle
Aug 22, 2015 06:52 PM
