Ultimate TBI mod what bit to use
Old Feb 11, 2004 | 06:07 PM
Lance Donlon's Avatar
Car: 91 1500 ex-cab pickup
Engine: 350 vortec
Transmission: 5-speed
for using the die grinder what bit should I use
Old Feb 11, 2004 | 06:20 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would use a cut off wheel and go around the lip. That is the fastest I have ever done it. They use a carbide bit and radius the inlet. Do not use a stone. It will get hot quick and you will get a nice coating of aluminum on your bit and render it useless.
Old Feb 11, 2004 | 07:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I used an air-powered die grinder with a cut-off disc. Then I used a flapwheel to smooth it all down real good.
Old Feb 11, 2004 | 08:28 PM
Engine: 350 vortec
I have had promblems with the carbide bit fulling up with aluminum and that why I haven't done the mods yet.
Old Feb 12, 2004 | 01:20 PM
vwdave's Avatar
Please dont use carbide bits to port aluminum. You use non-ferrous(sp) and you wont have that problem. Also make sure to use gear oil as lubricant.
Old Feb 12, 2004 | 10:52 PM
Engine: 350 vortec
Non-ferrous (sp) What? tell me more
Old Feb 13, 2004 | 12:03 AM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
a ferrous metal contains iron, and a non ferrous metal does not.
carbide is made up of ferrous metals. and since the metal is harder then what you are grinding instead of actually wearing away, exposing a new cutting surface, it will become clogged with the softer metal.
which is why using a non-ferrous cutting tip will not get clogged.
Old Feb 14, 2004 | 08:52 AM
Engine: 350 vortec
Where can I get one thanks for the help
Old Feb 14, 2004 | 04:47 PM
vwdave's Avatar
Summit sells them.
Old Feb 19, 2004 | 09:47 PM
Engine: 350 vortec
Bought a bit a napa for 28$ and was made for aluminum wow made that job fast and snapper motor know to
Old Feb 21, 2004 | 03:59 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
this one...
its IS a carbide bit, HOWEVER i beleive the design is what keeps it from EVER getting clogged, it also has not dulled after doing about 4 tb's.
I then used sanding drums starting with coarse then going to a finer grit.
customblackbird
Aug 15, 2021 10:16 PM
pimp2303
Jul 27, 2017 02:03 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
TheTraut88
Sep 7, 2015 05:22 PM
