So much for my dream...
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
Well, no TBI 406 for me
so it's back to modding the 305.
This is what I'm thinking.
LT1 cam (94 TA)
Vortec heads
performer rpm intake
hedman tork-step headers
transgo shift kit
some chip tuning by craig moates
and the 3.42's and limited slip i have
I know it's no 406, but do you think thats a good combo?
so it's back to modding the 305.This is what I'm thinking.
LT1 cam (94 TA)
Vortec heads
transgo shift kit
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Well it is right on par with every other modded L03 out there. Do those headers come with a y-pipe? Also are you going to mill those heads down some? Or have them machined so that you can use some 1.6 rockers with that cam? You should also look at upgrading your fuel system and possibly a larger TBI unit.
Car: 1991 Camaro RS
No y-pipe with the headers ($200, what do you expect)
get the heads milled to 58cc
and from what I understand, the stock TB should be plenty capable of supporting these mods....but I'm just going by what I've read.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
nebu,
usualy the machining is for the lift, and studs, you machine it for screw in studs, and also have the valves guides cut down for clearance. most people also check the pushrod guide slots (although not used, you need to check this) and clearance those further if needed.
Car: '90 RS
Engine: 377 LSX
Originally posted by Dewey316
nebu,
nebu,
RedGut86
Jul 12, 2010 04:37 PM
