Cam Question Need Help
Car: 1991 Camaro RS
Engine: 4 bbl 305
In the new Summit i got Edlebrock lists a cam for the 87-95 305-350 TBI engines.my question is seeings they list it for the TBI engines does it still need a custom prom for the engine to run right?? Any and all help is very much appreciated
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
that cam is no better then stock and its flat tappet, if u want a nice cam look into the lt1, theres a sticky on the top
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Edelbrock cams are very weak and not much bigger than stock. Because they are so mild you can get away with the stock tune. A custom tune would take that cam even high but you won't have any drivabilty problems with them. Not worth the money if you ask me.
