Cam & Crank
Old Feb 18, 2004 | 07:13 PM
qwik92rs's Avatar
Car: 1992 Camaro Heritage Edition
Engine: 305 TBI
Cam & Crank
Hey, I am going to be putting a cam and crank in my 1992 305 TBI, Auto. Which cam would be best if I do not want the cam to be loud? Also what crank would work well with that cam? I just want it to sound stock with a little extra power.
Old Feb 18, 2004 | 08:58 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Cam & Crank
You don't need to change the crank at all. Read the stuff at the top of the page as for what cam to go with. A cam will make your car a little louder but sound is controlled through the exhaust. Also, try a search on what cam to get. There are tons of things to consider before you look into a cam swap. Do you have a full exhaust? Do you have a good running fuel system? Are you prepared to burn your own chips? Based on your question it sounds like you may want to do a little more reasech before you get yourself in to deep. But we are here to help if you have any questions that you can't find through a search.
anesthes
Mar 10, 2016 10:35 PM
mddaniel
Sep 8, 2015 05:16 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 26, 2015 01:37 PM
