PROJECT UNDERWAY: cam/heads/intake/tbi swap!
Old Mar 2, 2004 | 11:35 AM
  #151
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I've talked to so many people who are running .475+ cams with stock vortec heads though... And I really think the retainer is far away from the valve guide. We'll find out though.
Old Mar 2, 2004 | 12:00 PM
  #152
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I put a pair of 8062 vortec heads on my car with 0.480/0.488 lift. The only change I made was putting Comp Cams 981-16 springs on. I can only tell you that the heads have given my no grief to date.
I haven't measured the coil bind with stock springs, so would have to rely on BMmonte's values- I have no reason to doubt him. It's just that the are so many articles out there with different max lift values for those heads when stock.
I think the best way to resolve this is to pull out a couple push rods and see if they are straight and check the valve seals for any signs of interference or damage.
S-D
Old Mar 2, 2004 | 12:43 PM
  #153
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
the lt4 HOT cam is .492" lift with 1.5" rockers. 5.25" lift with 1.6 rockers.
i'm pretty sure the maximum lift on stock vortecs is either .460" or .480", but that would only come into effect at higher rpms, wouldn't it? i thought the problem was the spring wouldn't be able to cycle fast enough and the valves would float. is that wrong?
is there a way to check the coil for output? i know you can take your ignition module to any napa store and check it, but don't know about the coil.
when my car died this summer, i spent over 800 bucks replacing distributors, wires, modules, labor for troubleshooting when i couldn't find the problem, etc. it ended up being a partially functioning ignition coil. before he goes pulling the heads off this thing, i think he ought to try every basic check .... twice.
1. if there's no way to test the coil, borrow one off a car that is working and try it. if i'd done that, i would've saved myself weeks of grief and hundreds of dollars.
2. have a friend check your wiring order. i know it's dead simple, but it could be being overlooked, you might be dyslexic or the victim of a druid curse.
3. pull the ignition module out of the distributor, take it to a napa store and have them check it.
4. check all grounds and fusable links.
5. pull the passenger side valve cover and #1 spark plug. slowly rotate the engine until you feel compression out of the #1 spark plug hole. stick a straw in the spark plug hole and slowly rotate the engine till the cylinder is at the top of the stroke. your timing mark on the harmonic balancer should be at zero. if it isn't, you probably have the balancer installed wrong.
5b. after placing the cylinder at tdc as outlined above, both of the valves on the #1 cylinder should be completely closed. ideally, you should be able to wiggle the rocker arms and have a little freeplay. if the valves aren't closed, you probably have your cam installed significantly advanced or retarded.
before i started pulling heads or pushrods, i'd make sure i'd double and triple check all of the above and more.
Old Mar 2, 2004 | 03:55 PM
  #154
Car: 1991 RS
Yes.... I was focusing only on the head being a problem- there are other things to rule out first.
S-D
Old Mar 2, 2004 | 04:09 PM
  #155
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
there is a little more to this. there is a point where the parts start to actualy hit each other, the pushrod his the side of hte hole where it pass through the head, retainer and lock hit the valve guids, or the spring actualy 'bottoms' out. when this happens you start to break parts, it is not fun. the other thing you have to be concerned about is the point at which the rocker arm studs, actualy pull out of the head, the hiehgt varies depending on spring pressure. the more pressure, the sooner they pull. this also isn't costant, one set may be fine with heavy springs, at .480 lift, another might pull at .460 with light srpings, this is sort of a matter of 'chance'
Old Mar 2, 2004 | 04:10 PM
  #156
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
S-D
first thing I'm gonna do is relocate that bad ground wire, then pull some pushrods and roll em around. after that I'll replace the coil and ignition module. if all else fails, I'll bxtch and moan about it to you guys some more.
Old Mar 2, 2004 | 04:11 PM
  #157
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I've got aftermarket springs, let me dig up the Comp Cams part number...
Old Mar 2, 2004 | 04:17 PM
  #158
Dewey316's Avatar
Car: 1990 Camaro RS
with aftermarket springs, you can probably get .480 lift or so before you bind anything, the question is if you have screw in studs, at more than .460-.470 lift, with aftermarket springs, if you still have pressed studs, you are asking for trouble.
Old Mar 2, 2004 | 04:18 PM
  #159
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Comp Cams p/n 981-16
Specifications:
* Outside diameter: 1.254 in.
* Inside diameter: .880 in.
* Seat load: 105 lbs. at 1.700 in.
* Open load: 295 lbs. at 1.250 in.
* Coil bind: 1.150 in.
* Rate: 423 lbs.
  #160
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
:lala:
Old Mar 2, 2004 | 06:14 PM
  #161
DM91RS's Avatar
Car: 91 RS
You are good to go on the spring bind issue with the 981's.
The two sets of Vortec heads that I have checked with a dial micrometer have both been consistant at retainer to seal measurements of .465".
If you subtract the .050 safety clearance you are down to the earlier mentioned .415". With the stock LT cams you are going to be close IMHO.
I doubt that anyone sent you the LT4 hot cam. I just bought a new (takeout ZZ4) cam from Sallee chevy and it came in the hot cam box as that was the cam that they take the ZZ4 out for.
Anyway you can correct for any of the LT stock cam clearance problems with shims and .050 offset locks.
Found anything new out?
Old Mar 2, 2004 | 06:31 PM
  #162
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
No new data to report... but how much do shims cost? lol
Old Mar 2, 2004 | 08:09 PM
  #163
DM91RS's Avatar
Car: 91 RS
Shims Comp Cam 4748-16 $6.98
Locks Crane 99045-1 +.050 $17.98
Goodluck
DM
Old Mar 3, 2004 | 06:05 AM
  #164
Dewey316's Avatar
Car: 1990 Camaro RS
:lala:
are you calling BS on the pressed studs pulling out with aftermarket springs at the .460-.470 lift range?
if you are, ask me how i know this. ask me why i know how to put in screw in studs with the heads still on the car, in 100*+ weather in a rush to get the car running.
Old Mar 3, 2004 | 07:04 AM
  #165
cgb's Avatar
cgb
If it were me....
BEFORE you pull the valve covers / pushrods etc.
I'd borrow a distributor / coil off a car, or just hit the junkyard.
Sounds to me like your're NOT getting spark.
An engine will RUN with bent pushrods....not good..but it will run.
After that I would verifty TDC, check the pushrods, then adjust the valves again...
Old Mar 3, 2004 | 09:11 AM
  #166
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
glad to see some one else also has the same measurements that I got. You also have to acount for casting variables as well as the operator of the seat cutter being a dumb a$$. When I checked some of my older heads I found some that were up to .020 different than the others. I wiped out 2 cams becuase everyone said that .460 lift was fine on stock heads with z-28 springs, including my machinist. WRONG, check yourself. Most older heads get retainer to seal interference at around .460-.465 lift some sooner some later.
Old Mar 3, 2004 | 02:18 PM
  #167
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I was just calling BS to the fact that I had to take the damn heads off the car again
Old Mar 25, 2004 | 10:14 AM
  #168
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
I love the fronts of our thirdgens for tool storage as well, it can fit most of my tool box on there, except when the socket you need rolls down and gets down behind the headlights. However i have found it a pain that whenever you have the intake off, those damn throttle, and tv cables love to hang out in the valley, especially when your trying to get the new intake on, and they just wont get outa the way
Old Mar 25, 2004 | 11:43 AM
  #169
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I can bend mine back and have the master cylinder hold them out of the way. I know exactly what you mean and this way keeps them far away and out of your RTV.
Old Mar 25, 2004 | 01:52 PM
  #170
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
its all good folks, the car is running. gotta tweak it a bit, but I'll update you on that part later.
Old Mar 27, 2004 | 12:55 AM
  #171
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
So what ended up being the problem? I haven't been on in a while and missed it.
Old Mar 27, 2004 | 01:10 AM
  #172
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Continued in another thread...
https://www.thirdgen.org/techbb2/sho...hreadid=231194
Old Mar 27, 2004 | 11:32 AM
  #173
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I had the valve lash set too tight
Anyway, I think I'm running lean. The car heats up very quickly, and it bogs when I floor it (and sometimes pops out the intake but not always).
Old Mar 31, 2004 | 07:41 PM
  #174
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
Originally posted by ShiftyCapone
Don't the front of 3rd gens make the best place to lay tools. I had about 3485647856465 tools on mine when I did my cam swap. I ended up scratching that place up pretty good
YES they do, i made a lower tpi intake outta sheet aluminium, thinking the hoood would close. little to my surprise its the best place to park your butt during a cam swap and it doubles as a tool tray.
Old Mar 31, 2004 | 07:53 PM
  #175
Z28GEN3's Avatar
Engine: 305TBI
I just cut the tab at an angle and the cover sliud back on without disrupting the oil pan seal.
How did you get the radiator support bar off. I could not get mine off for the life of me. I found where it was bolted to but could not get the bolt out for the life of me. I just had someone yank up on it while I slide the old cam out.
I practically had to drop my oil for that blasted front lip, next time a 2 peice cover is going on. I used a ring packing tool to manipulate the seal into cover, basically a round bar with a point and a hook on one end.
Old Apr 11, 2004 | 12:22 AM
  #176
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
FAST FORWARD ONE MONTH:
The car is running fairly well right now. It's very fast compared to the stock L03. It's still lacking the power under 1500 rpm (it can't squeal the tires from a stand very well, and it doesn't chirp the tires). I don't know if that's due to a bad AFR or if that's just the property of the cam. In any sense, I probably want a new torque converter fairly soon.
The car is getting bad gas mileage (12-13 combo city/hwy) and I don't know if that's just because it was running lean or not. I have bumped the fuel pressure (like an hour ago) but I don't know the effects of that until the next tank of gas. Am I getting poor mileage because I'm running lean, which the computer then tries to correct for it? Or am I getting bad mileage because the car is heavily modified and my C/R is only ~8.5:1?
Old Apr 11, 2004 | 12:42 AM
  #177
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Its because you have need tuning badly. I was only getting ~8 mpg until I started with good ol WinBin, and now GMECM Edit. From what I read, the ****ty performance under the stall speed means (we) need more pumpshot. Ima hook my wide band O2 up to it in a few weeks here after finals and really start tuning, Im sure you might want a bin of such a similar combo
Old Apr 11, 2004 | 08:13 AM
  #178
DM91RS's Avatar
Car: 91 RS
We have very similar setups. First the compression ratio ain't killing your gas milage. I get at least 20 with mixed driving. I go through several heavy throttle runs a day. (Why else did I mod it?) X-way is sometimes stop and go and generally otherwise 75-85mph. The worst I got was with the 350 untuned and it was still 18 mpg.
What psi are you running? And what injectors are you using? (I forgot sorry)
I myself am guilty of not enough tuning because of not haveing a laptop to run Winaldl..but that will change soon. I did run a scanner alot to get this close. Have you got anything to datalog with?
Old Apr 11, 2004 | 07:05 PM
  #179
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
haha very similar...
how do I read the bin? I think I need a chip reader, but are they cheap? I'm too scared to goto the DIY PROM boards, those guys are mean too.
approximately 14psi (about three threads left under the screw if that makes sense) and stock 55# injectors that came with my TBI. I'm using the stock TBI because I HATE HOLLEY'S LINKAGES! grr.... Anyway, I have not logged any data, but I've made three cables... NONE OF THEM WORK! I've been using this schematic and I've tried both data terminals (E and M)
Attached Thumbnails PROJECT UNDERWAY: cam/heads/intake/tbi swap!-interface2.gif
Old Apr 11, 2004 | 10:10 PM
  #180
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
dude with those mods that thing should destroy those rear tires something is off big time
i know this cause my LO3 runs high 14s and demolishes radial tires from a dead stop and then again in 2nd gear
Old Apr 11, 2004 | 10:15 PM
  #181
steve8586iroc's Avatar
Token, double check how you wired the switching transister. If it's wired wrong you won't get any data. Oh and by the way, where is the M terminal?
Steve
Old Apr 12, 2004 | 01:44 AM
  #182
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Steve
I tried almost every combo... I'm not using R3 or R4. I've tried two different NPN transistors. I'm not new to electronics...
And I really don't know what's wrong with my low-end, because I can BARELY spin the tires and they're not sticky tires either.
Attached Thumbnails PROJECT UNDERWAY: cam/heads/intake/tbi swap!-aldl1.jpg
Old Apr 12, 2004 | 01:57 AM
  #183
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
From what I understand you want to use the one WITHOUT the 12V source. That could be your problem...
Bruce (90RS305)
Attached Thumbnails PROJECT UNDERWAY: cam/heads/intake/tbi swap!-interface.gif
Old Apr 12, 2004 | 12:43 PM
  #184
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
the #4 pin is +12v from the computer itself...
Old Apr 12, 2004 | 10:33 PM
  #185
Do you know anyone in your area that is using winaldl that might let you try their cable and or laptop just to see if it might not be a cable related problem?
Steve
Old Apr 13, 2004 | 01:29 AM
  #186
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Steve
I dont knw anyone in the area with a computer controlled thirdgen.
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
