will a NOS Top Shot Nitrous kit fit a TBI?
Old Mar 4, 2004 | 12:47 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
has anyone here done it?
Attached Thumbnails will a NOS Top Shot Nitrous kit fit a TBI?-topshotnoskit.jpg
Old Mar 4, 2004 | 01:10 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
my guess is it would 'fit' on the stud, i am not sure how well it would work for performance, or if it would be located in a good spot for it to travel into the engine.
Old Mar 4, 2004 | 01:14 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
thats my thought too... i was hoping someone has done it by now (and is willing to post it)
i got a bottle for free (woot) so i figure, why not a small 75 shot on the TBI...
thing is, i dont have the hood clearance for a nitrous plate under the TB... so i figure a topshot system would both fix that, and look pretty stock..
i mean, if i cover the braided line with rubber PCV line, it'll look like some emmissions stuff...
not for street racing... but just to save the embaressment of having a low 15 - high 14second nitrous car.. lol
Old Mar 4, 2004 | 01:15 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
I've always wondered this too. It cant be as effective as their other systems, but its considerably cheaper. $489 on summit. Heres the link, im interested in knowing if this works.
-chuck
summit top shot
Old Mar 4, 2004 | 01:19 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Just thought of this, I dont think it'd flow in so well because we have injectors over the bores where as carbs dont. I'm sure those would screw with the flow considerably.
-chuck
Old Mar 4, 2004 | 01:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
-chuck
not only that, but look at the air cleaner stud.
it has two 90* bends in it.. making if offset.. not straight over the bores....
however.... if you think about it, its still going to be pulled into the motor anyway.. you misting it 2" above the throttlebody isnt going to stop the motor from sucking it in.
my only worry would be if there is somthing directly under it that the fuel would puddle in....
but if it works, it would be a TBI blessing...
so anyone going to try it? (or have tried it?)
Old Mar 4, 2004 | 02:14 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Maybe you could just buy the TBI kit parts that you need. I am not sure if they will sell it to you separetly but its worth a try. What are your hood clearnace issues? I cannot remember what intake you have.
Old Mar 4, 2004 | 02:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
im sure i could get the TBI parts, but all of them raise the TBI unit. i cant do that.. i have about 1/4" of clearance.. it JUST clears for engine movement without touching... so no way can i put a plate under it..
i suppose one of my other options is to just use a fogger kit and plumb it in just below the TBI on the intake. but they cost more and arnt hidden... not to mention, it would be coming in from one side....
thats because i didnt post it.
Old Mar 4, 2004 | 02:28 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You sneaky fool. Looks like it is time for a cowl hood
Old Mar 4, 2004 | 02:37 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
nevar! i like my flat RS hood, and im keeping it.
i think i'll jsut sell the nitrous tank and continue with my main project.. the eaton blower/MPEFI swap.
with current cash flow, motor wont be in until the end of summer, so i was just looking for a quick way to be a lil faster this year....
Old Mar 4, 2004 | 02:54 PM
Dewey316's Avatar
Car: 1990 Camaro RS
you could always do a fogger system UNDER the manifold
Old Mar 4, 2004 | 03:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol, that would require more money then i want to invest with something that im going to only use for a few months.
then again... i wonder what the resale on somthing like that is....
MrDude_1's Avatar
Car: 91 Camaro Vert
can you run a sub 100hp shot on a multiport N2O system???
Old Mar 5, 2004 | 05:26 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Modifications aside. . . what system do yall use for N20? Any clearance issues?
Old Mar 5, 2004 | 02:41 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
would that system also pump in more fuel as needed or would you just have to richen the fuel via the regulator?
Old Mar 5, 2004 | 10:39 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
if you want to get risky (and/or ghetto) you can try to drill out a straight hole across the intake manifold and fit a NOS spraybar in there. I've heard of people doing it at least, I know machine shops can do it. This way you could pay for a cheap "universal" kit without the plate, and then mill the manifold yourself.
or am I talking out of my ***?
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Dan's 83z28
Exterior Parts Wanted
Aug 20, 2015 02:16 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
armybyrd
Aug 10, 2015 09:23 PM
