What the hell is wrong with my LO3?
Old Mar 7, 2004 | 05:37 PM
LS1Formula's Avatar
Car: 1989 Firebird
Engine: Toilet Bowl Injection 305
Transmission: Autotragic
Two days ago it started sputtering and surging under load. At idle it was fine, but under load off idle, it was like a carbed motor with the choke set. Here's what we've done:
plugs and wires are nearly new
cap and rotor are nearly new
new ignition coil
new MAP sensor
new fuel filter
idle air control motor looks good
injectors are clean and spraying plenty of fuel
fuel pressure appears good
did a tap test on the computer and that was fine
I'm running out of ideas now. Any thoughts on what else we could try? Can't wait to get the LS1 swap done.
Old Mar 7, 2004 | 06:28 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: What the hell is wrong with my LO3?
new ignition coil
new MAP sensor
new fuel filter
I would check the timing and replace the fule filter. Both can cause the symptoms you describe.
Old Mar 7, 2004 | 11:33 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
CTS?
Old Mar 7, 2004 | 11:49 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by BadBlue91RS
CTS?
Could be but I would start at the fuel filter anyways. That most likely needs to be changed.
Old Mar 8, 2004 | 09:34 AM
Wezzeles's Avatar
Car: Camaro
check ur vacuum plugs
Old Mar 8, 2004 | 09:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
do you have a cat on it? a clogged cat will cause that. and if you have been running rich for a while, that will kill a cat in a hurry.
Old Mar 8, 2004 | 10:39 AM
LS1Formula's Avatar
Car: 1989 Firebird
Fuel filter has been done, and the exhaust is catless. What's a CTS? Crank trigger?
Old Mar 8, 2004 | 04:08 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Coolant temp sensor
Old Mar 8, 2004 | 04:46 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Did you check your base timing? I would also check the cat like Dewey mentioned. Run the car for awhile and pull it into a dark garage. Pear under and see if it is glowing red.
Old Mar 8, 2004 | 05:06 PM
LS1Formula's Avatar
Car: 1989 Firebird
There still is no cat on the car. I think we've got it traced back to the computer, so I'll rip it's guts out and replace it. I've checked everything else and there just isn't that much **** that can go wrong on a TBI engine. Blah. I need to hurry up and find an LS1 block.
Old Mar 8, 2004 | 10:28 PM
greg88sccamaro's Avatar
Car: 88 camaro
Engine: 5.7 tbi
what does it mean when it glows red and what could it be
Fixed your quote for ya.
Old Mar 8, 2004 | 10:37 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by greg88sccamaro
ShiftyCapone
When it glows red it is running vary vary hot and is not working properly because it is clogged and is backed up. It becomes a heat sink and acts like a furnace.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
aaron7
Sep 30, 2015 09:15 AM
