Please help, engine fan...
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I bought my RS at the end of last year and have yet to put it on the road (just meaning registering the car). Anyway, I noticed that the engine fan comes on immediately as soon as the the key is turned and continues to run all the time. Even when the key is just turned to the "on" position without the engine running the fan comes on. I know this is not normal...I also know that the car is stock and has no aftermarket PROM in it. What do you guys think?
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
It could be one of 2 things...
#1 Someone could have wired it to the ignition so that it came on with the key.
#2 The ALDL connector has been jumped putting it in field service mode and when this happens the fan automatically comes on with the key.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You have a broken coolant fan switch. When it fails its default is to turn the fan on all the time. The switch is under the exhaust manifold on the passenger side just behind the dip stick.
Car: '90 RS
Engine: 377 LSX
Originally posted by v8nate92RS
Thanks guys, I hope it doesn't cost much to fix this.
84z96L31vortec
Aug 20, 2017 12:16 AM
