engine stalls at idlle/ hard to start
my 88 camaro started stalling durring braking and now it's almost impossible to start, i put it a new i.a.c. valve new pressure reg, fuel pump is putting out 16 p.s.i. and when i try to start it no fuel will come out of the injectors. i checked all vacum lines. i don't know what else i can do. please help!!!!!!!!!!
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: engine stalls at idlle/ hard to start
the pressure was measured from the feed line. and the return line seams to be under preasure as weel. it seems like my injectors just aren't opening to allow any gas out/ some time i can get it to start it will run fine until the idle speed drops, then it will die and be almost impossible to start again
92camaroJoe
Aug 13, 2015 06:07 AM
