Fuel rail going to TB
Old Mar 29, 2004 | 08:53 AM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Transmission: 700R4 auto
As I was replacing my EGR valve on my L03 the other day, I noticed that one of my metal lines going to the TB was twisted and kinked up pretty good. It is 1 of the 2 going into the back side of the TB (it's the one on the passenger side). It's right where it attaches to the nut-like piece that screws into the TB. Could this be a problem at some point? If so where can I get a new line?
Old Mar 29, 2004 | 09:03 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuel rail going to TB
A kinked fuel line can deffienately be a problem down the road. The eaiset way to replace it is with the stainlais line conversion. I will have to get you a link on that one. You could try a junk yard and see if you can pull one off a wrecked car. I cannot remmeerb if the one you described is the feed or retrun line. Is it the smaller of the two? If so that is your return line.
Old Mar 29, 2004 | 09:17 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
I have that same kink in my line! I have it in my return line & the kink is right where the fitting is attaching to the TB. I noticed it while taking off my TB to rebuild it & install the GM vafpr. I think the previous owner took the line off & just twisted the line fitting without securing the fitting attachment on the TB. Then TWIST! So I'm checking out the junkyards for a replacement. Oh, & the one on the passenger side is the return line.
Old Mar 29, 2004 | 01:07 PM
atryko's Avatar
Car: 89 firebird
Engine: LO3 TBI 305
Thanks for the quick response. I figured that's probably what had happened, that someone just torqued it before screwing it into the TB. When I asked the guy at the parts stores I called, they didn't seem to have any idea what I was talking about. So, I guess I'll hafta take a look at the salvages.
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
