Help with Car
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Help with Car
Here is the low donw.....car runs "ok"....89 305 TBI 160,000 KMS. but here is the low down and i am trying to get an idea as to things before I start ripping into anything.
The car lays down a good smoke screen when I get on her. ......its not blue....its like its black. NowI know thats not "good"....what could it be...a bad valve....bad rings....something else??? I know she goes through a little bit of oil...but its not all that bad...any suggestions
I know I am being sorta vague on the details but anyone have any suggestions as to what it may be...I cant keep driving this car like this...I am srue I am going to get pulled over sometime soon with this...so this is sort of my "project" for this month
Dave
Dave
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Black could mean a lot of things. it can mean oil and fuel, fuel alone or a super mix of coolant, oil, and fuel. What does it smell like. If you are really righ you will smell unburnt gas in the exhaust.
Car: 89 RS, 91 GTA
Engine: lo5, lb9
Transmission: t5, a4
I would definitely look at a fuel problem if it's black smoke. I had an ecm go out in my GTA that caused it to dump gas. If it's really bad then be careful about running it until you figure out what it is. I wound up with washed down cylinder walls that caused me to lose the rings and now it burns blue smoke (oil) from the blowby. (Luckily just put the 350 (L05) in the camaro)
good luck.
good luck.
Linson
Aug 21, 2015 02:12 PM
