Is this a good deal?? ASAP
Old Apr 3, 2004 | 06:34 PM
87iroctpi's Avatar
Car: 92 cavalier z24 for now
Engine: 3.1
Transmission: auto
Its a 91 Camaro Rs. It has a 150,000 miles but only have 10,000miles on engine and trans. He is asking $3500 obo. It has this motor http://www.jegs.com/cgi-bin/ncommerc...89&prmenbr=361 I think that is the one b/c he said that it was a GM creat motor and it was $1700. Well one prob is that he but the 305 tbi unit on the 350!!! That is probably hurting performance right??? I would probaby carb it. I would change the cam b/c that is very weak cam. How bad are the heads on this motor?? 200hp 350 is sad if you ask me. Does this sound like a good deal?????? Thanks alot!!!!
Old Apr 3, 2004 | 07:40 PM
vjo90RS8's Avatar
Car: 2002 Z28
www.paceparts.com , look for the 92-93 caprice engine. The truck engine you listed is not roller and is about $100 more than the caprice motor. Although, if you dont care about the engine being roller then go with the truck engine because it is a 4 bolt main i believe.
Old Apr 3, 2004 | 07:42 PM
vjo90RS8's Avatar
Car: 2002 Z28
also i just found out that same engine is only $1547 from paceparts.com (the truck motor from your link), so you might want to go with them if the shipping cost is not too much
Old Apr 3, 2004 | 07:47 PM
87iroctpi's Avatar
Engine: 3.1
Transmission: auto
no this car ALREADY has this motor in the car. I would change the cam b/c it is so small i was just woundering how ****ty (or good) the heads are??? And if the whole car would be a good deal?? Thanks for all the help!
Old Apr 3, 2004 | 08:12 PM
vjo90RS8's Avatar
Car: 2002 Z28
the heads are probably the worst 350 heads every produced by GM according to most people. They are swirl port heads which are good for low end torque but dont flow to well at higher rpms, they are definately not performance heads.
Old Apr 3, 2004 | 09:08 PM
87iroctpi's Avatar
Engine: 3.1
Transmission: auto
so that creat 350 also has swirl heads like the 305??? If they are ****ty swirl heads on the 350 what would be some decent heads for a decent price?? I thought somewhere i read something that you would buy some heads for $500 from GM? What do you think if car would run in the 1/4 mile if i changed the cam, 1.6 rr, 3.73, and i carb it??? thanks for the help!
Old Apr 3, 2004 | 10:10 PM
vjo90RS8's Avatar
Car: 2002 Z28
vortec heads are great flowing heads right out of the box. check prices at www.sdpc2000.com
Old Apr 4, 2004 | 02:46 PM
Teal91rs's Avatar
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
Heres some advice my pop gave me... "buy the car if you like the car itself. dont buy the car just cuase it has a nicer engine than the rest for all you know that could be one big ball of **** and plus geting a 350 already put in the car doesnt that kill the experance of haveing your car and put what you want in it? dont you wana have the joy of droping that 350 in and cranking it up for the frist time knowing that you put that in there?"
Old Apr 4, 2004 | 06:16 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your main problem is using the stock PROM. That motor is good that it is a 350 but it is bad because it has garbage heads and a non roller block.
hectre13
Dec 11, 2023 08:14 AM
9192camaro
16
Feb 3, 2019 12:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
Hello, Michael
Aug 20, 2015 03:19 PM
ChevyZ71
Aug 13, 2015 07:30 AM
