after cam and head swap????
Old Apr 7, 2004 | 08:30 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
what should i be getting after cam and heads swap im using LT1 cam and 416 heads with 1.94 intake and 1.64.and z28 springs.what else do i have to get to run open throttle with out back fireing.what should i be running in the 1/4mile with stock 2.73 open rear end.Also the 700r4.i plan to either get 3.73's or 4.11.
Old Apr 7, 2004 | 08:33 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the equipment to tune it.
i am guessing the back fire is when you first mash the gas, in which case you need to richen things up, and give it more pump shot. with a combo like that, you will need quite a bit of tuning.
you will probably want a converter, but the LT1 torque curve seems pretty flat. but i am guessing a higher stall will still help.
gears are of course a given.
Old Apr 7, 2004 | 09:05 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Dewey is dead on. Your car is begging you for a custom burnt chip.
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
