ET Update From Friday Night
Old Apr 10, 2004 | 09:00 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ok guys ET is a little off but check out the 60 foot :rockon:
R/T-.558
60'-1.893
330-5.934
1/8-9.353
MPH-71.34
1000-12.347
1/4-14.883
MPH-89.04
Old Apr 10, 2004 | 09:03 PM
25THRSS's Avatar
Good times still, but you lost a few mph somewhere.
Old Apr 10, 2004 | 09:06 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Those really are great times. That is an amazing 60 foot for an LO3. You should see some awesome numbers once you start adding mods that increase the ponies. You deffinately have the traction down.
Old Apr 10, 2004 | 09:08 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
yeah i dont understand the better 60 and lower trap speeds that one has me boggled
Old Apr 10, 2004 | 09:54 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Your better 60 times are due to a great launch and being a good driver. The low trap speeds are because you have that poor stock LO3 up front.
Old Apr 10, 2004 | 09:55 PM
25THRSS's Avatar
true, but IIRC he was trapping around 92 or so mph before.
Old Apr 10, 2004 | 09:57 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
yeah before it turned 91mph ah oh well im still stoaked about the 60 foot
Old Apr 10, 2004 | 10:07 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
My geuss would be that his improved traction limited his motor from reaching its power band as fast as it would if there was some slip. Top fuel dragsters will trap the best with moderate slip all the way down the track. We all know how close an LO3 is to a top fuel car . I am pumped to see his times when he gets some top end on that car. If he can pull those 60 foot times with even a mild cam and some tuning he could easily knock off a half second.
Old Apr 10, 2004 | 10:21 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
yeah thats what im worried about i just dont have the resources or the knowledge to burn a chip for a different cam or heads
Old Apr 11, 2004 | 02:27 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
What all you got on that thing to push it into the 14's? I know I have one of the faster bone stock L03's on TGO from what I've seen (not bragging, so no flaming guys) and the best I've pulled is a 15.3! Yeah, that 60' IS amazing! Wish I could do that...
Bruce (90RS305)
Old Apr 11, 2004 | 11:26 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
That's an amazing 60' man, real nice. When a little bit of wheel slip is factored in, as soon as the tires "catch", the motor is usually in a higher RPM bracket (closer to peak HP) so even though you spun, you kept your revs in a more powerful part of the powerband and you get higher MPH, but a slower 60'.
Old Apr 11, 2004 | 11:36 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
What was the weather like between the two runs?
Old Apr 11, 2004 | 12:44 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
what all suspension mods do you have done to that thing? those are amazing 60' times. keep up the good work!
Old Apr 11, 2004 | 07:09 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
To Chuck- The weather was pretty good down in the low 50s
the suspension is bone stock of course i removed the sway bars both front and rear to give the car better weight distribution out the whole
but heres the list again of all the mods down to the exact part and brand
AC Delco Rapid Fire Plugs
Accel Super Coil for GM dual Connectors
Accel Cap and Rotor Button
MSD 6A Spark Box
GM Performance Parts Ignition Wires
March Underdrive Pulleys (two piece set, crank and alt.)
K&N Air Filter
Edlebrock Air Cleaner
Hypertech Thermomaster Chip
160 Thermostat
Holley Flowtech Headers and Y pipe
ALL emissions deleted (smog pump,a.i.r hook ups,cat)
Straight pipe in place of converter
Dynomax Catback Exhaust
K&N Breather Filter
3.42 open rear from a 1985 2.8 Sport Coupe Camaro
B&M Megashifter
B&M 3500 Stall Converter
B&M Trans Pak
P275/50R15 BFG Comp TA Drag Radials
Weld Wheels
Holley 670 CFM Throttle Body for GM Trucks
Home made TBI spacer 1/2 inch thick
Old Apr 12, 2004 | 12:06 AM
25THRSS's Avatar
wow, and you still don't have a posi yet? That's very impressive for a 1 wheel peeler.
Old Apr 12, 2004 | 06:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
those are some great times, although i wasn't suprised to see a monster stall converter, and DR's on your mod list
Old Apr 12, 2004 | 08:41 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
yeah the next mod is defenitly posi
Old Apr 13, 2004 | 01:30 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Hence the great 60' times. But damn 3500 stall?!?! Thats beefy for the stock cam. Imagine with the posi.
U need to start crackin those manifold bolts and head bolts and get to work.
Old Apr 13, 2004 | 02:08 AM
90RS305's Avatar
Ohh duh forgot about the other thread you said all that stuff in. Yeah, rockon dude, I can only imagine what your times look like with posi....
Old Apr 13, 2004 | 03:36 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: WC T-5
MSD 6A Spark Box
K&N Air Filter
160 Thermostat
K&N Breather Filter
B&M Megashifter
B&M Trans Pak
Weld Wheels
I thought you were also running an aluminum driveshaft and aluminum drums?
Old Apr 13, 2004 | 05:51 PM
steve8586iroc's Avatar
It IS possible to get both wheels to hook with a non posi rear end and drag radials or comparable tires. It's not hard, you just have to heat both tires before you get to the line. It usually takes getting the RR heated first then it's easy to get the LR heated. Then just come off the line at your best rpm (just depends on your converter or clutch condition).
Steve
Old Apr 13, 2004 | 08:43 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
oh yeah duh i forgot that stuff i got a aluminum drive shaft from a 2000 trans am and a set of aluminum brake drums from an 86 IROC
Old Apr 14, 2004 | 01:43 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Yeah man, if you're putting down 1.8X 60' times, posi is definitely the least of your worries, I'd say the biggest gain is to be had by burning your own proms.
Old Apr 14, 2004 | 07:50 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
yeah man thats got me worried stiff cause i want to put a cam and a set of heads on it but im just a hill billy and dont have the resources or the knowledge to do custom chips
Old Apr 15, 2004 | 10:21 AM
Kleen RS's Avatar
Car: 92 25th Anniversary RS
Engine: A slow one. The infamous 305 TBI
Transmission: 700 R4
I read in another post about a company that burns chips for cheap(around $50). You just call em up and tell em the set up and they do it all for you.
Check out www.TBICHIPS.com
Hope they can get you in the right direction
Old Apr 15, 2004 | 10:48 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yup that is who about 99% of TBI modders turn to. The guys name there is Brian.
Old Apr 15, 2004 | 09:14 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
thanks a million guys maybe now i can start on the inside of this mean little small block
Old Apr 16, 2004 | 02:33 PM
johnjm22's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Do you think you will be able to get it into the 13's?
Old Apr 17, 2004 | 12:28 AM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
im gonna try like hell:hail:
Old Apr 23, 2004 | 02:53 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Hey guys, where are all of you mounting your MSD's or boxes like them? I can seem to find a good spot to mount mine and that is what is delaying the install of mine. I have a Crane HI-6 with coil to install. Any recomendations would be great. I still have have AC if that helps with recomendations.
Bill
Old Apr 23, 2004 | 06:27 PM
90RS305's Avatar
Bill
That'd be a better question to ask in the Tech/General forum or the Electrical forum. Try to stay on topic with the thread header please!
Old Apr 23, 2004 | 06:54 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Dennis,
I have gotten two chips from Brian so far. He has done a good job for me. Just keep in mind that it will take a long time and a lot of chips to get it dialed in right. But if you don'e know how to burn your own, Brian is a good place to start.
Bill
Old Apr 23, 2004 | 09:52 PM
weberusn's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Sorry about that guys. I forgot.
Thanks for the info on the chip though. I will definitely give brian a hollar.
Thanks again,
Bill
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
gord327
Sep 29, 2015 10:18 PM
