TB spacer
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No, but it can mess up the geometry of the linkages, namely the tv cable. Even very small changes can have profound effects on how the transmission shifts and operates.
Car: 2002 Z28
i had a 1/2" plastic spacer that worked great, but i no longer need it because i am now using an Edelbrock TBI intake. I have heard that people usually have trouble with 1" spacers.
Car: 89 Camaro RS
Engine: LO3
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Hey welcome abaord. Check out the "new to TBI" thread up top. It talks about spacers. You can run a 1" spacer but it will require some fab work to your fuel lines and throttle brackets. It is a lot of work for zero to little gain in power.
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
youll have to bent the hell out of your fuel lines to make them fit.
